Ford Sunroofs Suck - Seal Issue Discovered
skyak
F250, 911, Lightning
I always try to buy Fords without sunroofs due to all the leaking horror stories. Unfortunately this was not possible on the Lightning Lariat. Decided to check out the sunroof today for the first time and left rear corner seal has issues. Argh.
Ford F-150 Lightning Ford Sunroofs Suck - Seal Issue Discovered 1669575069975
Ostrichsak
Colorado, USA
What do you mean it's not possible on the Lightning Lariat? I've got a Lariat being built now w/o a sunroof because it cost additional to add and I'm not really a fan of them anyway. I think the Platinum comes with them standard though, right?
skyak
Really? Is it an ER? Did I miss this?
Fast911
Tim
San Mateo,Ca
Silverado sold
Unfortunately
My moonroof/sunroof seal looks just like the pic you have posted in several spots all around the seal. Does your sunroof leaked? I tested mine during several washes and it does not leak inside. Have you test your sunroof while washing the truck?
Ford F-150 Lightning Ford Sunroofs Suck - Seal Issue Discovered 6608FBC5-A0AC-4FA0-9E21-F82761B69376
Ford F-150 Lightning Ford Sunroofs Suck - Seal Issue Discovered 3E5BBD08-7F8B-4D3F-99F4-52DDF1753BA4
Ford F-150 Lightning Ford Sunroofs Suck - Seal Issue Discovered 9F085D14-CE72-4540-A712-0EC42F71D860
Ford F-150 Lightning Ford Sunroofs Suck - Seal Issue Discovered BF7FDBDD-EA3F-475C-A8A1-AD050426F439
Reactions: cal
rdr854
Northern Virginia
You can post your VIN and I'll pull up the window sticker.
If you have a 511A ER Lariat, you have a panoramic roof.
Canadian spec trucks configured differently from US spec trucks. According to the build and price on ford.ca, they have a choice of the 510A or 511A equipment group with the extended range battery.
skyak
No mine does not leak (yet). Amazing how poor the installations are. Is this normal or acceptable? How does it get past QC?
OK. That's different. He never said he was in Canada.
