Grumpy2
- Nov 23, 2022
- Central Oregon Coast
- 23 F150 Pro SR
- Occupation
- Retired Hvy Construction
Thanks for this video, State of Charge is a fact filled source regarding charging that I have been subscribed to for some time.
I ordered the Lightning only because of the 10kw built in "generator", even with a SR battery, it will be the equal to a massive home power wall that you can drive around.
My lowest cost power is between 9pm and 6am as it is for many folks, so charging with the grid is best done during those hours. I need a new roof and I am thinking of getting solar panels at the same time.
Did you investigate a automatic transfer switch after your big solar inverter that would select either the grid or solar to recharge your Lightning?
