- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2001 FORD RANGER, 2023 F-150 LIGHTNING
So I wonder how many new owners are having battery problems?
Also wonder if it was a manufacturing problem, and environmental (heat/cold/etc) problem, too many fast charging cycles, or what?
My model year 2012 has an air-cooled battery, and some people living in Phoenis Az, where the weather is a lot like Egypt, had battery pack issues, rapid degradation, and Nissan had to settle a class action law suit on the issue. I never had any problem living in the Virginia Piedmont though.
It is good that Ford is taking care of it right away (it seems) under warranty.
Of course you have to hope they know what the problem really is and fix it correctly.
And that it never occurs again, i.e., it is not a 'lemon' that will never work properly.
Was it a 2022 or 2023 MY truck?
I read that "The 2022 Ford F-150 Lightning has eight recalls. That’s a bit higher than expected. The first issue involves inoperative windshield wipers that reduce visibility. Also, flicking parking lights may reduce visibility.
Improper airbag deployment increases the risk of shrapnel, and some of the wheel lug nuts may have been improperly tightened, causing the wheel to separate from the vehicle. Plus, the drive shaft may fracture, resulting in the loss of power.
Something is up with the steering wiring that may cause the wheel to turn in unintended directions, the trail brakes may fail, and there’s another driveshaft issue.
These problems seem to be related to electrical issues and manufacturing problems. The Lightning has racked up 95 complaints related to these issues."
But they said very few battery issues arose at least at the time.
Personally, I'd like to see EV's have modular batteries that could be entirely swapped out easily and quickly like what the Chinese company Nio is doing - no need for fast charging stations and the resulting down-side (fast charging decreases the lifetime of a battery):
NIO Power Swap
Fully-automatic battery swap in just a short coffee break.
Enabled by over 1,400 patented technologies, NIO Power Swap, the first of its kind, offers an ultimate and exclusive power service experience. It takes only 3 minutes* to swap a fully charged battery. Automatic battery and electric system checks are performed during each swap to keep both the vehicle and battery in the best shape.
Videos of the process at: https://www.youtube.com/channel/UCnzvsquKNk5zpok-PzGRy7A/videos/videos
The is a company that has a pilot program (AMPLE with fleet vehicles in Ca) where they retrofit any of several EV's so they can utilize a swapping station:
Fastest to a
full charge.
Using modular battery swapping, Ample can deliver 100% charge to any EV in under 10 minutes. As battery density increases, Ample maintains the same delivery efficiency.
https://ample.com/
And some market analysts say there it could become a big thing in the US and world-wide:
EV Battery Swapping Market Players
Some prominent EV battery swapping companies covered in the industry are Amplify Mobility, BattSwap Inc., BYD Co. Ltd., ECHARGEUP, NIO Inc., Gogoro Inc., Kwang Yang Motor Co. Ltd. (KYMCO), Leo Motors Inc., Lithion Power Private Limited, Panasonic Corporation, SUN Mobility Private Limited, and Tesla Inc.
https://www.globenewswire.com/news-...Report-by-Acumen-Research-and-Consulting.html
Not sure why the have Tesla in there - Tesla decided against swapping at one point, but maybe they are still considering it?
Anyway, personally I'd much rather someone replace the whole battery at the dealership and then let someone else fiddle with the individual cells (or modules) inside the battery, a more specialized task.
Good luck!
NIO Power Swap
Fastest to a
full charge.
https://ample.com/
Good luck!
