Walle1jm
I’ve described on my own thread but just for documentation purposes, I am no longer able to L2 charge, I receive a fault. Dealer won’t be able to get it in for several weeks.
Interesting. I seem to get it regularly, yet when I check the LVB voltage it is perfectly fine. I've had the message since new and the dealer has multiple F150Ls with a similar situation. If you've had yours for a year, you probably have a 2022 (lucky you - you probably have heated steering wheel and onboard scales too!). I wonder if something changed in the hardware between 2022 MY and 2023.So of interest here.. I've had my truck for over a year now.
I charge at home and I plug in when I get home at 6:00pm the latest. My truck is set to charge beginning at 11:00pm so it sits plugged in for 5 hours every single night before the charging starts. and I've only gotten this error once before. . I have nothing aftermarket hooked up.
I found a post that suggests the LVB Battery Management System (BMS) can get out of whack and cause this error. I found the procedure for resetting the LVB BMS so I'm going to try that and see if it clears it up.So of interest here.. I've had my truck for over a year now.
Update [ Priority Update 23-PU0306-BCF-DET } ??Same issue here after the OTA update.
Yep that is the update. Same morning, the error codes arrived. I don’t know if they are related or just a coincidence. I’m on vacation 3 hrs from my dealer. Trying to figure out if this this thing is safe to drive home (at reduced power) or not.Update [ Priority Update 23-PU0306-BCF-DET } ??
It is coincidence. If your truck will drive it is safe to do so but if the fault reoccurs it will limit your power significantly. Call the customer relations team, ask for the BEV team, and tell them what is going on. They can help if you end up needing a rental to get homeYep that is the update. Same morning, the error codes arrived. I don’t know if they are related or just a coincidence. I’m on vacation 3 hrs from my dealer. Trying to figure out if this this thing is safe to drive home (at reduced power) or not.
are folks thinking the fault errors are caused by the update (and is there a fix?)
I have a 2022 ER
I got the same errors yesterday. It was on my Ford charge station pro charging overnight and I noticed I had a charge fault warning in the morning. Those errors came up afterwards while driving. I only had 20% power available while driving.
When I got home I logged in with FDRS and printed all the errors as well as battery module information before clearing the codes. Once the codes were cleared everything was back to normal.
I’ll reach out to the battery team for guidance but it’s my only vehicle right now and I can’t let it just sit at a dealership for weeks.
