Surprised by tire wear
Whammy Bar
Whammy Bar
1971 F100 + 2022⚡Lariat ER
775 ftlbs of torque. If you ever had a diesel truck tire wear is similar.
I had a Banks tuned Powersmoke that was driven like a rental car for 110k mi. Tires made it 45k.
I thought the truck had a even weight distribution. Rotating tires is traditionally due to higher weight up front from the engine creating more wear. So is rotating every 5k on a vehicle with even weight really going to make a difference?
Whammy Bar
Whammy Bar
I would suggest scientific dimes, it would be much more dramatic.🤪
Will report back after the tropical storm passes. Dimes are currently underwater.
My seat of the pants assumption is... Because it sends so much power to the front + how squirrelly the front gets under any sort of spirited acceleration + the steering and braking responsibility of the fronts ... The front tires are gonna wear pretty hard.
Your wear might be why the Hankooks were discontinued. My Generals are holding up much better. I have about 22k on them. 10k rotations and set to 43 psi.
Ford F-150 Lightning Surprised by tire wear 20230820_163059
I had an 88 F250 with the Navistar 7.3. I lived on a gravel road 3/4 mile from hard roads. I went through 5 sets of tires before I sold the truck with 120,000 miles.
Acacia1731
Ryan
Cincinnati, Ohio
2022 F150 lightning pro
My SE Pro with 22" General Grabber HTS60 was measuring 7/32" on front and 8/32" on rear when rotated at @11K miles. I keep them around 42PSI.
I guess that puts me on track for about 25K life span.
I'm not totally understanding this. The PRO is only available with 18" wheels. Do you have aftermarket wheels?
Acacia1731
Ryan
Cincinnati, Ohio
That’s correct. I changed to the Ford Performance 22” wheels with the same Grabber tires that come stock on Platinums.
mr.Magoo
2022 Lariat ER, AMB
Not to get completely sidetracked , but Bronze or Black, and have you noticed any significant drop in range ?
Mine are Bronze, I got Continentals instead of General, haven't noticed much more than what was expected (Lariat vs. Platinum) from going to 22's / heavier wheels.
Acacia1731
Ryan
Cincinnati, Ohio
Link below to the wheels I have. Total weight with 33" Grabber tires was 87lbs, vs 70-something for stock 18's with 32" Michelins. I don't have solid data to back this up, but it seems I've lost about 10% range/efficiency and acceleration (0-60) vs what others are reporting.
https://performanceparts.ford.com/part/M-1007K-S2295GB
Whammy Bar
Whammy Bar
Interesting that those tires would have a lower pressure.
I'd be curious how much range loss at that lower pressure.
I'm at 2.1 mi/kW lifetime average. Not sure if that helps with anything.
