Installing a heat pump
Yellow Buddy
Smart Ass
1.8 at that speed sounds good to me. My regular commute is 1.25 hrs each way and once a month I do a 4-5hr drive one way. In a few more months I'll be able to better judge. The 240 is actual from 90% to 12% gotta keep driving though
The 1.25 isn’t a good judge but the 4-5 would be. It’s just so many darn variables, but give it a shot. If you’re getting 240 from 90-12% then that means you’re getting 240 out of 78% of your battery, that projects out to 308 miles from 100% to 0%. Or did you already project it out?
If you didn’t, that’s more than what I get. I consistently get 280-290 miles out of mine from 100%. It’s been so reliable that I’ve more than once arrived at an EA with about 4 miles indicated range remaining - trusting EA to work is another story….lesson learned.
I’ve gone nearly 200 miles with a 25’ camper in tow in cooler temps up and down mountains, so I do get a bit skeptical to see only a range of 240 from full with nothing in tow - unless we’re talking temps below 30F.
Electric_hillbilly
Enrique
Grass Valley, CA
2023 Lighting
Military
You make a good a point, Temps are not usually that extreme over here, going down there is no issues, mileage is great. Coming back up the hill different story. But I'm not towing/hauling so I should be good.
I haven't installed the pro charger yet, so I've never gone pass 91%. I will feel better once I can get that extra charge
Txxthie
Robert
CT
2022 TM3 RWD LFP
I would like to know outside the conditions I listed what are the other conditions you are referring to. I am agreeing it is beneficial when the conditions are met. It depends on your use case scenario. When you indicate extreme temps are not the norm for the majority of the country, you are actually saying heat pump is not needed for the majority of the country since heat pumps make the difference when you actually live in those areas. A heat pump is not going to make a noticeable difference for example for someone that lives in Florida. I live in the DC area, I owned a model 3 without a HP for 2 years and then upgraded to a Model Y 2,5 years ago with a HP (I still own this vehicle) and now I have been driving a 22 Pro for about a year and I went through the last DC winter with this vehicle. From my personal experience, if I drive short distances without pre-condition I don't see a noticeable difference in losses between my model 3, model y and lightning in winter time driving. The most noticeable difference I saw was the winter time long distance travel between my model 3 and my model Y. HP did its job and kept the cabin toasty without using resistive heating.
The video I have referenced 2x explains the current generation of Tesla’s HP. Have you watched it, or are you basing your opinion on your own experience? It’s not whether they can produce heat. It’s the efficiency in doing it. A resistive heater is better in producing heat, but it is essentially a hair dryer. It’s a carryover from ice which it’s use/draw didn’t effect anything. With a BEV a resistive heater is a huge energy draw and killer of efficiency. Watch the video to find out how much. 😉
I also had a 2018 TM3 Dual motor without a HP. It was not very efficient when using heat about 325 Wh/mile.
Conditions that call for heat vary by individual. There are a lot of people that live NE of you and they need heat right now.
My temps today in CT
Ford F-150 Lightning Installing a heat pump IMG_5730
vsansal
Volkan
Arlington,VA
F150 Lightning Pro, Tesla Model Y Performance
The video I have referenced 2x explains the current generation of Tesla’s HP. Have you watched it, or are you basing your opinion on your own experience? It’s not whether they can produce heat. It’s the efficiency in doing it. A resistive heater is better in producing heat, but it is essentially a hair dryer. It’s a carryover from ice and its power usage wasn’t as noticeable. With a BEV a resistive heater is a huge energy draw and killer of efficiency. The goal is to produce a more efficient electric vehicle is it not?
I did watch that video and I also base it on my personal experience as well. I don't argue HP is less efficient, on the contrary I am saying it is more efficient when certain conditions are met. What I am saying is, with my day to day situation, I am not seeing much of a difference between the two. You said, your M3 consumption was 325 Wh/mile without HP, can you tell me if you tried under same conditions a vehicle with HP? If so what was your consumption? If your daily drive consist of uninterrupted longer drives, HP is more efficient, for shorter trips the consumption end up being about the same in my experience. Instead of using energy for resistive heating, it needs to use energy to heat up the front motor I believe on the model Y, so the HP can pump that heat to the cabin on the shorter drives or if the vehicle is cold soaked outside. I still believe all EVs should include HP and it would be beneficial under certain conditions but I wouldn't trade my 22 pro for a 24 model because it has an HP module is what I am saying.
Txxthie
Robert
CT
2022 TM3 RWD LFP
I have a 2022 TM3 LFP (Gen 2 HP) with 15K miles currently (purchased new). My gf drives it 60 miles a day (60% highway 40% city) I see a 10% hit (4.9 to 4.4) when using the heat vs Lightning which is 20% (2.3 to 1.7). Another post in this thread shows the same 10% draw with the newer Tesla HP.
My ideal Lightning:
HP, LFP(100% charging), DC preconditioning (non routing based), decoupler (similar to eGMP vehicles), and better aerodynamics. The Lightning very light for a BEV truck, Ford got that right!
Kev12345
Ram 1500
Maybe ford will bump up the battery capacities for ‘24 as well. This combined with a heat pump would be a welcome improvement!
vsansal
Volkan
Arlington,VA
My ideal Lightning:
That makes sense on a 60 mile commute. My commute is around 5 miles each way totaling 10 miles. I don't see any significant difference in consumption between my Model 3 w/o HP and Model Y w HP. My lightning also seems to get the same amount of hit like you mentioned around 20% on the same commute. The biggest difference I actually notice is using the seat heaters I have in my model Y vs 22 pro doesn't have one. I believe that's a more significant improvement compared to having a HP or not in my case. I don't need that much heat on my model Y if I am using the seat heaters.
Txxthie
Robert
CT
2022 TM3 RWD LFP
I couldn’t live without the heated seats in my Pro. IMHO: Manufacturers should not make any EV’s without heated seats or heated steering wheel. They can also provide other ways to heat the cabin and keep the windows clear. Toyota’s radiant heater on the bZ4X seems like a good idea and how about heated windshields or areas near the wipers?
Yellow Buddy
Smart Ass
Speaking of which, jumped into my truck this AM with temps under 30F.
I was smart enough to precondition the truck so when I jumped in, it was toasty warm. I snuggled my tushy into the warm seat and put my left hand on the warm wheel, reached to shift and…shifter is ice cold. Seems like a major oversight. Time to sell the truck.
Txxthie
Robert
CT
2022 TM3 RWD LFP
Jokes aside, Is that carryover shifter really necessary in the Lightning? Why do we need to keep bringing the entire legacy supply chain along into BEV’s?
If legacy wants to make a profit with EVs they must start designing them using 1st principles. Create software defined vehicles using zonal centralized computing. Develop it all with digital twins.
John McElroy (Autoline) has been preaching this for years. His latest video on this topic was on the YT channel Batteries Included Podcast
Jseis
SW Wa
I roll about 90 miles a day on US101 in SW Wa. Mild weather and rural roads means in 9200 miles since late June I’m averaging 2.5 mi/KW. My “worst“ climate use might be 5% and that’s mostly to keep glass from fogging.
Headwinds really impact Mi/KWh but tends to balance out as summer headwinds are NW and winter headwinds are SW. A heat pump would modestly impact range though in my daily commute I’d never be impacted at all. As weather gets into mid 30’s here on the coast it’d likely have a noticeable impact in the morning a few days to week or so per month in winter. It’ll be interesting to hear Lightning owners results. Biggest gains will ultimately-likely be aero w/T3.
Yellow Buddy
Smart Ass
Necessary? No, but I can appreciate it as a transition for anyone who's not coming from a Tesla. I'm sure there's an element of - let's spend the $10 extra to keep the current F-150 customers.
Personally I prefer a column shifter whether that's on a ICE vehicle or the older Tesla's or the Rivian. I haven't used but I wouldn't want to have my shifting buttons on screen.
This ^^^
Txxthie
Robert
CT
2022 TM3 RWD LFP
Tesla figured out how to offset the exorbitant costs of the battery and scale production to not lose a ton of money. Ford was incorrect to "transition" customers and its BEV sales numbers and losses back that up. The current generation of Ford EV's will end up being the best built, but it is not a sustainable business model and will not scale. Future Ford BEV's will look more like Tesla's and have less parts, amenities, and options. Battery costs don't seem to be decreasing anytime soon. Toyota was correct to sit out this generation of EV's.
