9.6 kW Option?
JamesH11
James
Vermont
Ford Lightning Pro extended range
entrepeneur
I am considering buying a Lighting and wondering what exactly is the difference when adding the 9.6kW option. Do you not get the 240v outlet without this option?
RickKeen
Rick
F150L SR Pro
sw engineering manager,
Also, its a pre-req. for Max Tow on the SR battery (additional battery cooling is part of the pro power system). I will rarely use the Pro Power, but I got it because I wanted Max Tow.
Danface
Dan
Central Mass
2023 Lightning XLT
I am going to use the 9.6KW as a battery backup for the house. The weather is getting more energetic which, as we're seeing, means more power outages. A week after I ordered the truck, we had a 15 hour outage which was a first according to people who've been in the neighborhood a long time. One of these days my truck will show up too!! :)
Be aware that 9.6 is the combined output of the 2 inverters. The ProPower in the bed is 7.2 KW of that, the other 2.4 KW inverter supplies the interior and frunk receptacles.
Danface
Dan
Central Mass
2023 Lightning XLT
Good point, I was planning on only the 7.2KW output for the house. Thanks for clarifying!!
I would also point out the following.
The truck can provide power to the house IF:
- It is parked at the house at time of outage.
- You are home to connect it (unless you have it setup for the automatic solution).
- It has enough charge to power the house for the length of the outage.
We went with a whole house generator because if the truck is 5 states away, it powers nothing...
Fastnf
CALIFORNIA
2023 F150 lightning
I actually use both inverters. I use the 7.2 kw for 240 volt items well pump, mini split, water heater, and use the 2.4. Kw for the 120 volt items, refrigerator , microwave, internet.
biers
Thomas
SW Washington
eGolf
Technically three inverters.
2.4kW for frunk/cab
2x3.6kW for bed. One for each leg.
Don’t even want to think of how many hours I poured over the specs in 2022 🤪
2.4kW for frunk/cab
From a usability standpoint, it’s easiest to consider the ones feeding the bed as a single unit.
biers
Thomas
SW Washington
eGolf
For 240 completely agree.
But good to know the design should you need to put a big load on it from multiple devices. I carry a 4 way splitter that gives me 2 120 outlets on each leg. I’ll probably never need it, but like to have it.
Have you tested using it? I struggle visualize how that would work, presuming the two inverters are internally connected at the 240V center point.
biers
Thomas
SW Washington
eGolf
I haven’t but out of spec on YouTube did it when charging 5 EVs from the Lightning.
1375mlm
1375mlm
Ford Maverick Lariat
On the 2.4 kW versions, is the truck divided into 2-3 inverters also? Or everything on one?
bub
F150 Lightning Plat
Its one inverter feeding the same outlets everywhere on the base model.
The propower adds on a 2nd inverter at 7.2kw for the 9.6kw total. That second inverter is a split phase inverter and is required for the 240v bed outlet.
