CSP campaign and updates
THX1138
Pennsylvania
Hello,
I am a new owner of 2022 Lariat ER. I think it was a mannequin on the dealer lot. Ford Pass says I have two CSP Campaign alerts.
1 : PAAK not functional (23B81)
2: High Voltage Battery (23B57)
My VIN is 1FT6W1EV4NWG01211
Could someone please tell me what other updates need applied?
Sync4 about displays version 22228_product revision 539.
I'm wondering what else needs updated?
Thank you in advance!
That's all you show at the moment, no recalls and only two CSP's as you stated,
One of the FDRS guys [ @rugedraw ]can look up your VIN to see if there are other pending updates for the truck, based on the Sync version, you will eventually start getting catchup updates a few months after taking ownership
If Mike doesn't beat me to it, I'll look it up for him, but need a bit to do so. Out and about at the moment.
theblunden
NC
2023 F150 Lightning XLT
I'm convinced I'm never getting the SOC% update 😭. I've gotten soo many letters in the mail about over the air updates needed per my VIN 1FTVW1EL8PWG03685 might have to waste a day at the dealership for them to not do anything. I have only received 6.4 as of late.....
@THX1138 Here you go:
Ford F-150 Lightning CSP campaign and updates 1703826490277
Your list is below:
Ford F-150 Lightning CSP campaign and updates 1703826793346
THX1138
THX1138
Pennsylvania
Thanks. Dumb question: will the updates listed remediate the two CSP findings?
I kind of think the APIM update will address the PAAK issue? But I'm not sure about the high voltage battery CSP?
Thanks again.
Thanks again.
I took before and after pics from the tech's FDRS screen when he did the battery CSP.
EDIT: It updated PCM, ABS, SOBDM, SOBDMB, SOBDMC, BECM, GFM2, . It did not update BCM, FHCM, SCCM, WACM, CMR, DDM or PDM.
THX1138
THX1138
Pennsylvania
Good point. When the mobile tech was here (light bar, BECM), he just applied the updates, did not do the test as far as I know. I forgot to ask him to do it and he seemed a bit rushed to get to his next appointment.
Does the software update make testing/ monitoring the battery modules more comprehensive?
Sort of. The software update tightens up the tolerance of allowed module imbalance before an error code is set. Some owners whose dealer updated the software without doing the module test started getting battery faults shortly afterwards. The dealer would have found the faulty module(s) and replaced it(them) had they performed the CSP as written.
THX1138
THX1138
Pennsylvania
Good afternoon,
I just came from my dealer who performed work on these two CSPs. My dash shows 91% on the left side? Does this mean I have some failed batteries? Wondering what I should do next? Thanks
Ford F-150 Lightning CSP campaign and updates 20240103_114622
Ford F-150 Lightning CSP campaign and updates 20240103_114634
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Good afternoon,
That’s available power, not battery capacity. It is probably just reduced because the batteries are cold. It should come back. Also, after some of these updates it can take a while for the cells to rebalance and the software might be limiting you until that process completes. It just means it might take 4.5 seconds to get to 60 instead of 4.
THX1138
THX1138
Pennsylvania
Ok, that's good to know. I knew I was going to have this maintenance, and I was waiting a few days before charging it. I read to charge to 85%to maintain optimum health... I'll give it a few weeks to see how it recovers. Thanks!
rdr854
Northern Virginia
I came out to my 22 Lariat ER at lunch time and it said 93% power. There has been no work the truck since Thanksgiving and the high voltage battery was down to 60%. I put it on the charger (Level 2) when I got back from lunch to charge it back up to 80%. When I started the truck, it read 100%. I do not recall having this happen previously.
I also did not have any error messages or warning lights on the dash. Except for the 93% power, everything looked normal.
