You don't? Its angular, boxy shape is a literal aerodynamic nightmare that leads to vortex shedding and turbulence. Elon Musk has even said as much on an interview with Joe Rogan.That was some interesting reading.
But I don't understand how it can be so inefficient ....
Pretty sad. Perhaps their only real designer is now building the Lucid Gravity.
20 miles is a horrible range test. If I leave my truck out in the cold, jump straight on the highway for 20 miles I can get as low as 1.3mi/kW, but my truck averages 2.1mi/kW over 20,000 miles.
If you wanted to calculate it you would take 1 and divide it by 1.7 (in your case because you said you got 1.7 mi/kWh) to get kWh/mi. Then you take that number and multiply it by 1000 to get Wh/mi. The number is really just the reciprocal of mi/KWh. Unlike mi/kWh lower numbers mean better efficiency because you're describing how much energy you use per mile rather than how many miles you traveled per unit of energy.I tried looking up this Wh/mi stuff and I still don't understand how it's calculated. Can somebody that understands it please post the calculations they use to achieve it using the Lightning as an example?
I drove into work this morning. ER Lightning. Went from 88% to 65%. I believe my mi/kWh was 1.6 or 1.7. What is my Wh/mi?
1/MPK x 1000.I tried looking up this Wh/mi stuff and I still don't understand how it's calculated. Can somebody that understands it please post the calculations they use to achieve it using the Lightning as an example?
Thanks, guys. Maybe it's because I've never owned a Tesla, but I like mi/kWh better.1/MPK x 1000.
1/1.6 x 1000 = 625 wh/mi.
