Thunder1809
- First Name
- Doug
- Sep 23, 2023
- Washington
- 2023 F-150 Lightning Lariat ER, Carbonized Grey
- Occupation
- Engineer
I spent yesterday putting in one of these Generac 6852 with an electrician so I did it correctly. We put in a couple of tandem breakers to get to 10 circuits like I had on my previous transfer switch. But it is not working correctly while using ProPower from the truck. I don’t get the bonded neutral fault like I did when I plugged into my other transfer switch last week.
When I switch over from line to generator with the truck plugged in I get a ground fault. What is odd is that it does not occur immediately, but sometimes after minutes, sometimes after a few seconds and sometimes when I turn on one additional breaker. We did a lot of trouble shooting and checked that each circuit was wired correctly and the neutrals were pulled off the neutral bar in the main panel.
I brought out my gas generator and hooked it up and it works fine. So we were both wondering if there is a problem with the GFCI or the inverter with the truck. Is there a way the dealer can check this? If the ground fault occurred immediately I would think it was our installation, but there were times when we had it running with about 500 watts on each leg and it would run for a while and then would fault.
Any ideas are appreciated.
