mr2urbo004
CA
2023 Ford F150 Lightning Pro, Tow Tech,
Realistically, it would be great to have pictures of the coolant lines leading to and from the 7.2kW inverter and what they connect to. In the best of all possible worlds, I'd want those, pictures of the orange high voltage line leading to that inverter, and pictures of part numbers for both coolant lines, the fittings those lines connect to (likely some sort of tee), and the high voltage connector. The realistic part alone would be great and probably a that's necessary.
Probaby some junk yard has these truck and has the bed removed. That would be a good start in getting the parts too.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Junk yard lightnings aren't really a thing yet. Ones being sold by copart are going for too high prices to sit in a salvage yard.
123XYZ
SF Bay Area
2023 F-150 Lightning Pro
mr2urbo004
CA
DDan1020
Daniel
Seattle
2013 Honda Accord
I'm curious if there are any recent updates here? I have a friend that's looking to offload their used F150 Lightning and I'd love to tinker with upgrading the Pro Power Onboard. (Obviously it's just easier to buy a Lighting with 9.6 kw installed, but seems like a fun project).
mr2urbo004
CA
Just cant find anyone that can take their bed off to see the exact patt # and how the hose connect.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
I have a friend that just bought a 23' with 10kW PP. Unfortunately he got spray in bed liner, but I can snoop with an inspection camera and phone. I'll get pics this weekend.
mr2urbo004
CA
Where you able to get pic?
jweggy
Joshua
2024 Ford F150 Lightning Lariat 2021 Ford Mustang MACH E GT performance edition
Any progress to be had here?
jweggy
Joshua
Any luck getting pictures?
jweggy
Joshua
I wonder if the folks at Munro could help get this data and/or pictures?
HOTAS
Lightning Flash, Tesla MY, Chevy Volt, PiPrius
Airbus Pilot
I got a somewhat detailed video of the 9.6 Pro Power Plus 7.2 rear inverter hookup detail. If you pause the video you can see the electrical and coolant connections. With the right parts I feel it could be plug and play.
It’s gonna require the inverter, mounting bracket, bolts, 2 wiring harness (inverter in and inverter out/bed receptacle) and coolant hoses. The wiring harnesses could be the big problem if they different between 2.4 and 9.6 trucks.
I think it could be done with spare tire removal and WITHOUT bed removal. Just a guess. The inverter is the smaller component to the rear.
Video to follow when I can figure out how to fit this forum’s size requirements.
Ford F-150 Lightning Installing Pro Power Onboard 9.6kW Inverter - OEM IMG_7083
Ford F-150 Lightning Installing Pro Power Onboard 9.6kW Inverter - OEM IMG_7084
Ford F-150 Lightning Installing Pro Power Onboard 9.6kW Inverter - OEM IMG_7085
Ford F-150 Lightning Installing Pro Power Onboard 9.6kW Inverter - OEM IMG_7086
Ford F-150 Lightning Installing Pro Power Onboard 9.6kW Inverter - OEM IMG_7087
Ford F-150 Lightning Installing Pro Power Onboard 9.6kW Inverter - OEM IMG_7088
Ford F-150 Lightning Installing Pro Power Onboard 9.6kW Inverter - OEM IMG_7089
Ford F-150 Lightning Installing Pro Power Onboard 9.6kW Inverter - OEM IMG_7090
jweggy
Joshua
@HOTAS
where did you get the video?
