AT&T outage affecting telematics??
I'm reading reports of cell phone service, particularly in the south and southeast of the nation experiencing issues.
If this is impacting your mobile device are you seeing any issues with the vehicle telematics?
https://www.foxbusiness.com/lifesty...ationwide-verizon-tmobile-users-also-affected
UPDATE
The rest of the story ...... software update caused this outage!!
https://abcnews.go.com/US/att-outage-impacting-us-customers-company/story?id=107440297
rdr854
Northern Virginia
My telematics and cell service are working. However, AT&T and FirstNet are down at the government center a few miles from my house.
So wait, I can't constantly check the 12v battery level of my car/truck? :unsure:
Or receive OTA's as they are distributed, on the bright side of this incident, it's a timely issue to test the reliability of the WiFi communications in distributing updates. The CNN article had more useful information with a suggestion by AT&T that it's customers put their phones on a WiFi network if available to use WiFi calling.
Ish
‘23 Lariat ER
PaaK didn’t work this morning but other telematics did work. My AT&T wireless modem didn’t have a signal.
That shouldn't be the case.
PaaK, i.e. using the phone as a key, should work just fine, as you approach the vehicle, because it's via Bluetooth.
Using the phone to lock, unlock, etc. should NOT work, unless you have PaaK setup and are within Bluetooth range.
Interesting here - my truck is in the garage, and should be connected to Wifi. I'm in the house with phone on Wifi and full internet (on the phone if I turn Wifi off I get "not connected to the internet" and only the SOS signal, not ATT at the top of the phone). I am checking my LVB battery a few times a day as I'm hoping overall it improves after having the 12v battery sensor replaced.
If the truck reliably used wifi, this process should still happen without cell service, but the truck won't update. The app spins and then stops.
This indicates that Ford can't find and wake the truck up via Wifi, only cellular. A major shortcoming. We already know that it won't start a SW download until you start it.
Danface
Dan
Central Mass
2023 Lightning XLT
I'm having issues too ... maybe putting the TCU fuse back in would fix it? LOL :)
Further investigation - I went to the truck - it didn't wake up when I approached or after opening the door. This tells me my LVB SOC may have dropped again overnight. No reason it shouldn't wake up after opening the door.
To say the least - it does start after brake/push button and comes to life and connects to Wifi (although the app knew to tell me to drive to reconnect services). It will check for SW updates, but nothing will get the truck to update the app (still says last connected 3 hours ago) and the LVB SOC will not update Ford. So there are definitely certain processes that only work over the cell signals.
With full wifi on both truck and cell there are still communications that are nerfed.
Ford F-150 Lightning AT&T outage affecting telematics?? IMG_5787
Ford F-150 Lightning AT&T outage affecting telematics?? IMG_5788
Dave70
Wisconsin
2023 Ford Lightning
My ATT phone is down all day, and truck can't connect with ford pass. It did remote start this morning, but it was on my home wifi network then.
2021 Ford F150 Platinum FX4 EcoBoost
I have checked VIN's on over a dozen vehicles today already and I had no issues pulling connected data on any of them including my own. That isn't to say no vehicle are affected, but so far, I have not found one that is told me connected data could not be accessed.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Absolutely, today was the first day my truck did not remote start from my FordPass command in over a year.
tls
New York
2022 Lightning
PaaK is definitely not supposed to require cell service. I routinely use it in places (Ski Belleayre, I'm looking at you...) where there's no cell service or Wi-Fi in the parking lots.
Ish
‘23 Lariat ER
agreed, this was the first time it’s failed for me so it likely was a coincidence, just wanted to throw it out to the world to see if anyone else had the problem. Seems it was a me problem.
