Ford charger with Tesla solar and Powerwall
tnugentfl
palm coast, fl
2023 f150 lightning lariat ext range
I have researched this extensively and there is no known way to make this work. And, even if you did it would be at the expense of your warranty protection on the truck and Tesla system.
Bigbuckhunter71
Steve
South Jersey
2023 LIGHTNING Pro
OK
Thanks for your help
I have talked to Tesla ,they have new wall charger that will transfer power from truck to home and powerwall.
I will keep you updated with my progress on this install thru the upcoming months.
Paperwork is almost complete and
I plan to start this weekend.
OK
Is this the one that is included with the Founders series Cybertruck? Does it come with a CCS plug as an option? I figured that would solely be NACS.
tnugentfl
palm coast, fl
Not sure how that would work. As I I understand the setup with the Cybertruck, the system uses the inverter on the truck. Fords system installs an inverter in the home. I think Tesla's system is superior in this aspect and have no idea how that could work with our trucks.
Bigbuckhunter71
Steve
South Jersey
2023 LIGHTNING Pro
Uncle Teddy?
I start my tesla powerwall 3 site survey today,I let you know how it goes.
I finished my electric service last weekend,I'm ready!
Bigbuckhunter71
Steve
South Jersey
2023 LIGHTNING Pro
Site survey from Tesla is in the works for PW3 ,I had to install a 100amp fireman disconnect switch to to disconnect Tesla subpanel inside gateway.
Still no word from (nubkub)
NCMike
Raleigh, NC
2022 Red Lariat Lightning
So has Tesla told you that your F150 can power your home through their Powerwall/inverter/charger?
Kevin22
Kevin
Southern California
Chevy Volt
Systems Test Engineer
Here you go. All work done using local people. Tesla did not have anything to do with the install. New main panel. New sub panel for 20 circuits protected by the new PowerWall. SunRun sucks but we are installed and working as expected
Ford F-150 Lightning Ford charger with Tesla solar and Powerwall IMG_7826
Bigbuckhunter71
Steve
South Jersey
2023 LIGHTNING Pro
I'm in final approval with my set up
I'm going back and forth with Telsa and telsa certified contractor.
The electrical contractor(local) guy is awesome but Tesla ( California) needs to get out of the office and see the real word construction.
Bigbuckhunter71
Steve
South Jersey
2023 LIGHTNING Pro
How did you commission the powerwall without a certified tesla approved contractor,if tesla didn't do any work o. It
Bigbuckhunter71
Steve
South Jersey
2023 LIGHTNING Pro
Great install! I like how you covered up all the wires to the gateway and sort of recessed the cans.
Do you have any pics of the charger wies connected to the PW?
Did they use the DC wires from the charger?
Is there a communication wire from charger to gateway?
Scorpio3d
SS/IBA car wash owner
So I just want to be sure I understand this Kevin22 installed The powerwall 3 and is able to have the same functionality as the Ford/Sunrun HIS? I ask because I just had my FCSP installed and I am currently in the process of adding solar and would like to have the ability to use the truck as a back up, power source in the set up!
Ford F-150 Lightning Ford charger with Tesla solar and Powerwall IMG_0467
