Rotary shifter possible
ryun
Earth
That's pretty cool! I wonder what happens when they press the L?
I thought the shifter folding down was really cool when I saw it in an ad for the lightning. But now having it for awhile I think I've only pushed the shifter down once legitimately. Most of the time I push it down just to show someone how it works. Would have much rather they stuck with a column shifter.
LazyLightningATX
Doug
Austin
'23 Lariat ER
Would be really interested in this if it were relatively simple...from those pics it looks pretty decent. It looks like they did some plastic shaving/trimming on something in that one pic, so probably had to 'customize' a piece. Parts don't seem to cost too much...wonder if it uses same wiring connections/plug and play-ish?
Someone needs to make a kit for this!! The stock shifter kinda feels cheap and is just kind of a waste of space when it could literally be a button or that dial or whatever since it is totally electronic.
The Weatherman
Dean
South Central KY
Had the dial shifter in my Mavericks and our current Explorer. I would have preferred it in the Lightning, but I don’t see myself messing with the transition now.
Hank42
NY
2022 Lariat ER
Yay! Now we can fold down the table and eat a full meal while driving! Oooh and put the laptop there too to watch youtube while driving ;)🤣
Nice hack though - looks good. Now if there were only a mod to change the color of the ignition button light to change color when the truck was truly "on".
ddimit
Sacramento, CA, United States
2015 Tesla model S 2023 F150 Lightning Lairat
Manager
Cool idea but what impact will this have on Warranty and service? I can see a dealer refusing to touch it since the drive train control has been modified.
right, us 'older' gentlemen are not looking for projects, we just like driving this amazing vehicle 'as is'... my wife's new EV9 also does not have the 'rotary' dial, but a 'twist' of the driver 'stalk' behind the steering wheel... took some time to get used to, but anything is doable after a while : )
Lance
Spokane WA
23 Lightning Pro ER
Medicine
I wouldn't mind putting this on the dash with an extension cable from the console. Free up the console entirely.
COrocket
F-150
Neat idea. Although I’d rather have a column mounted shifter and 4 cup holders, the dial seems like a good option. I just hate how much slop there is in the stock shifter. Makes it feel very cheap.
ctuan13
Chuck
Pittsburgh, PA
I'm with you there, I like the mechanical feel of the shifter, it's a skeumorphism that really enhances the tactility and easy of use of the shifter. I can shift into any gear without looking down. I would much prefer the column shifter over a dial.
I actually posted a previous thread about possibly implementing this, but one of our handy members responded saying after some investigation, it seemed like our Lightnings have a different steering column frame that doesn't have the required bolt holes for mounting a column shifter.
My Mach-E has the knob. I can shift without looking at it as easily as I can in my Lightning.
RickKeen
Rick
F150L SR Pro
sw engineering manager,
Can you still engage the emergency free-wheeling Neutral mode?
What happens when you press the L?
Vakatack
Eric
New Jersey
2023 F-150 Lightning - Platinum
Console to Rotary Shifter 2023 Lightning Platinum ~$200
Hey guys, I tried to be thorough here but if anyone has any questions or if I forgot to mention something let me know I’d be happy to explain further. I saw this mentioned a bunch of places but didn’t see it done anywhere so I thought I’d post.
$90 Brand New on eBay
Ford Escape 2020-2022 Shifter - Part # PZ1P-7P55-AC
$50 for all 3 parts
Main Console Tray - ML3Z1513530AA
Console Rubber Mat - ML3Z15045G34JA
Console Plastic Insert - ML3Z15045G34EA
Harness Connectors and Wire - $50
Female Socket Part # 1326133-1 - 2 Pcs
Female Socket Shield Assembly Part # 1326132-1 - 2 Pcs
Male Pin PCB Connector Part # 1438543-1 - 1 Pcs
Receptacle Terminals 1326028-1 - 22 Pcs (order a few extra in case you damage any)
20 Gauge Wire - You can use any wire but I chose to get all different colors. You need 11 wires and about 2 ft of each.
The shifter dial finish is almost an exact match to the dial on the 15” screen and is illuminated. The blue light matches the rest of the interior lights. The dial functions exactly as it should and is very smooth. If the car is in drive and you shut the power, or you open the door, it will immediately shift into park for you without the dial physically rotating. Additionally, the L button in the center functions exactly like the N button for the 30 min neutral mode.
After pulling out the screen, the trailer brake has a few small tabs holding it that just snap right out. You can either throw it behind somewhere, since there’s plenty of space, or if you plan to use it, you can cut out a space for it somewhere else. It seems like under the Power button for the car there is a good space for it. I don’t ever plan on towing anything so I tucked it behind out of the way
The round part of the dial is exactly 3 inches in diameter. I used a 3 inch hole saw to drill out the trim and then a dremel to make the notch for the bottom part. I cut it out on cardboard first to get the exact size then I traced it in its final place before cutting.
The plastic mounting holes on top and bottom of the shifter need to be cut off to allow it to fit snugly and stick out like it’s supposed to. I used a hacksaw to get a clean cut. I also needed to cut some plastic behind the hole to allow it to fit. After fitting the shifter into the trim, I tried pushing the screen back in and was able to see which plastic pieces were interfering. I used a utility knife and dremel for most of the plastic cutting. At the end the shifter was held snug and almost squeezed exactly into place so that it doesn’t need any fasteners. The screen is still snapped in and very sturdy. I was afraid it might be shaking after cutting the plastic but it’s totally fine.
Removing the old console shifter is really simple. The side trim pieces, left and right of the cup holders, pull right out by hand. Then the top of the cup holders plastic trim piece pops up. You can take it off without removing the screen but there are two tabs that are tough to squeeze out. If the screen is off the top plastic trim of the cup holders pulls right up. It’s all connected with plastic tabs so by hand or with a trim tools it’s really easy to take out. After you remove the plastic there are 4 10mm bolts holding the shifter housing. One is underneath the small plastic door in the front, and the other 3 are easily visible. Once you remove them you can slide out the shifter and disconnect the wires. In its place you can put the Console Tray for an OEM finish.
You may want to keep the shifter inside the tray which is as easy as making a small hole for the wire and securing it down and then getting some sort of trim to go over it. I think it’s a total waste of space which is why I put it next to the screen. It does fit inside the tray deep enough to open the workspace for anyone interested.
You need a harness about 24" minimum to extend the cable to reach the new location. After about 2 weeks of searching for a harness or for someone to make me one, I finally decided to make it myself. I was able to find all of the plastic connectors from Digi-Key (linked below). Making the harness was pretty easy. The only tricky part was that they don't sell a straight male connector that you can connect with metal pins. The male connector is meant to be soldered to a circuit board (which I don't really know how to do). Instead I was able to straighten the pins out in order to connect the existing cable in the car to the extension harness. I've added pictures of all of the connections. You need 1 Male Pin Connector and then 2 Female Sockets, and 2 female socket shields to lock the sockets in place. Essentially you are making a female to female cable and then the male connector fits snug into the original female cable. There is no way to lock this connection in place so I used a zip tie to secure it and then zip tied that entire connection down onto an anchor point so that it doesn't move around. You also need the metal terminals that the wire gets attached to. I'm not sure the proper way to connect these but I stripped a bit of wire and squeezed the first metal tabs down onto the bare wire and the lower tab onto the jacket to hold the cable in well. There are 11 wires used out of the 18 sockets. I copied the existing wiring to make the harness and I used 20 gauge wire with a silicone jacket from Amazon. I think the existing wiring is 22 gauge but the 20 worked fine for me. The silicone jacket makes it very flexible. After I put all of the pins in and the connectors on, I just wrapped the cable in a nylon braided sleeve to keep it protected. I ran it along the driver side trim and up behind the screen.
Ford F-150 Lightning Rotary shifter possible IMG_0283
Ford F-150 Lightning Rotary shifter possible IMG_0253
Ford F-150 Lightning Rotary shifter possible IMG_0251
Ford F-150 Lightning Rotary shifter possible IMG_0252
Ford F-150 Lightning Rotary shifter possible 7-Jul 29 2024 08_28am-xi8H
Ford F-150 Lightning Rotary shifter possible 6-Jul 29 2024 08_19am-oNs5
Ford F-150 Lightning Rotary shifter possible down-net_http20240729-93-q83fn7
Ford F-150 Lightning Rotary shifter possible 1-Jul 29 2024 07_19am-N3SJ
Ford F-150 Lightning Rotary shifter possible 2-Jul 29 2024 07_19am-iShm
Ford F-150 Lightning Rotary shifter possible 15-Jul 29 2024 10_32am-B4z7
Ford F-150 Lightning Rotary shifter possible IMG_0282
Ford F-150 Lightning Rotary shifter possible down-net_http20240729-86-jls0lf
Ford F-150 Lightning Rotary shifter possible 19-Jul 29 2024 10_58am-iUyh
Ford F-150 Lightning Rotary shifter possible 25-Jul 29 2024 12_35pm-Lb3s
asianman35
asianman35
Baltimore
2023 Antimatter Blue Pro
$50 for all 3 parts
you should make and sell those extension cables!
