v2h8484
I think you meant "neutral" transfer switch.If you have a manual transfer switch setup you have a separately derived system.
Yes, correct! Thank you.I think you meant "neutral" transfer switch.
not allowed here in bc. bc hydro doesn't allow them due to solid state switching. I don't think they're allowed in Alberta either. maybe stricter standards in Canada? BC also doesn't allow simple generator interlocks. need to go with proper transfer switches here.These are UL1008M approved. If there was a significant safety hazard, that testing would have shown it.
Any luck with this? I’m about to have an Enphase Solar System installed and am looking to do the same thing.Yes one should turn off the breakers for automatic high consumption devices.
The instructions also state solar systems must be disconnected via the associated switch. I am trying to work with Enphase to support this meter collar generator input when one of their System Controllers is installed. Wish me luck!
