PTS/FDRS VIN Check Thread
FLSpartan04
Daryl
23 F150 Lightning XLT ER
Not in queue right now, but hopefully you continue to get more since you seem to be on their radar lately.
Thanks for checking! Guess I’ll have to wait for the next series and of updates to come through. It seems like they push them through in groups, so hopefully I’ll get 6.1,2,4 in short succession once they start.
Connor776
Connor
Salt Lake City
2023 Ford F-150 Lightning
Automotive Programmer
So I did all my updates using FDRS. Is there any way to push OTA updates to my truck? Is there anything I've missed? I still don't have battery percentage on anything besides the calm screen. Will my BMS sensor need to be replaced in order to receive these OTA updates? I keep my truck plugged in all the time and set to 70% max charge. I don't drive it much and keep the 12v on a truck charger in addition to the J1772 charger. Here is my vin 1FTVW1EVXPWG30128
please let me know if there's anything else I can do!
Thanks!
CRAIGC540
Craig
Moreno valley
Technician
Window sticker is attached and shows no deletes. Your truck seems to be favored by the OTA gods and has a very extensive and healthy OTA history. Only missing 6.13.0 and a few PU updates.
6.13.0 is for if you have blue cruise which I do not correct?
Thanks!
Did you do the GWM I see on 4/11? You are still showing some modules pending updates and you are not on the latest Sync version. If you do not have the SoC on your IPC, it is because you were most likely not showing all the updates you needed at the time you were doing the updates. This is due to a issue affecting many vehicles where the next updated needed to progress through the process was now showing for you on the server. Do you still have the Mongoose?
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1713272819471-0c
Correct. That and/or the PU-CMR-FX is for the CMR and only BC equipped vehicles have BC. I do not see any mention of BC on your window sticker.
Connor776
Connor
Salt Lake City
Yes the GWM module updat on 4/11 was me. So I actually have a VCM 3. What's odd is after doing all the updates I found see on FDRS I don't show anymore. Im probably missing something to be honest but I'm not sure what I need to do.
I don't have access to FDRS until later when I get home to my laptop, but the list of updates I sent you were released VERY recently and it is possible FDRS was not showing them then but would show it now. However, those updates will do nothing to get you passed Sync 23159 and release the other updates you need for the IPC update to be released. Give me a bit. I will PM you soon.
rdrude
Robert
Spring, TX
2023 Lariat SR
New owner here. Purchased 23 SR Lariat 2 weeks ago. Having some minor issues that Ford think may be fixed by updates. Dealer said they pushed all available updates but I find that hard to believe. Here is the VIN:
1FTVW1EL8PWG22852
TIA!
THX1138
Pennsylvania
Good afternoon,
Could you please look at my VIN for any remaining updates? 1FT6W1EV4NWG01211
It went through a lot of updates since I bought it last December. Thanks!
Shadow2222
Tyler
Ohio
Jeep Wrangler 4xe
The last two times this truck was started, it reported many codes where the APIM was losing comms with many other modules within the network. I am not a tech and do not consider myself in an expert by any means. maybe it's nothing, but I can tell you after looking at hundred of vehicles that this is not normal. See attached. Also, the modem is still in fleet mode and would need to be activated as a retail unit for updates to come in
Hi again! They supposedly went and picked up the truck from the dealership (trade between dealers to facilitate this purchase) so I’m assuming it would’ve been started. Could I trouble you to check to see if it showed the same behavior again so I can let the salesman know?
vin is 1FTVW1EV1PWG38182
ditkafan1985
NOVA
2023 F-150 Lightning Platinum
Morning all. I was hoping someone could pull the FDRS info for my newly purchased 2023 F150 Lightning. I already have the mongoose plug and a battery maintainer/charger on the way. My vin is: 1FT6W1EVXPWG28125
1FTVW1EL8PWG22852
TIA!
All they did was update the OBCC. Nothing else. Modules needing updates are below. Need more details on the "minor issues", but your truck is reporting an ethernet failure code between the GWM and APIM. Those ethernet codes are automatic red flags to me when something isn't right.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1713367903178-ry
Good afternoon,
You've gotten all the Power Up updates through 6.13.0/CMR-FX. You're missing a few of the PU updates. Overall your truck is in a good place in terms of updates.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1713368807833-fh
Nothing yet. The modem is still in fleet mode. It needs to be activated to retail before anything has a chance to happen.
This is what PTS is showing. Remind me after 7pm eastern today when I'm home and I'll pull the list from FDRS for you.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1713369028185-3f
rdrude
Robert
Spring, TX
2023 Lariat SR
Thanks for the help with this. The issues I am having is the parking sensor blocked error and the drive mode is greyed out and unable to be selected. The adaptive cruise control is wonky which I am contributing to the sensor issue. Sure do appreciate your service to the community on this! Much appreciated.
I think your truck needs to be looked at by a dealer for those issues.
rdrude
Robert
Spring, TX
2023 Lariat SR
Agreed. I contacted them and they will be picking it up to take it back to service. Do you know which software version I am on? I am still a little confused on all of the terminology. Thanks again.
