PTS/FDRS VIN Check Thread
Haven’t driven in months.
1FTVW1EV0PWG04668
You have the new GWM update sitting in your queue from earlier this morning. Go to the truck, start it and manually check for updates. Leave the truck running for 10 minutes or so and that should be enough for it to install.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1718377392653-i3
[/QUOTE][/QUOTE]
djwildstar
Guy
Atlanta, GA
2023 Lightning Lariat ER, 2023 Mach-E GTPE
Information Security
Hi! Could you please check my VIN 1FTVW1EV0PWG14214
I haven't seen an update in a very long time, but recently got the low-voltage battery sensor (CSP-23B70) work done -- and still no updates. So I thought it would be worth checking out.
Thanks!
Thanks!
Your truck is on the latest Sync version and the modem seems to be working just fine. You do not show a lot of pending updates. I think you may only be missing the 6.13/CMR-FX OTA as far as the power up updates go; maybe the 6.8.0 IPC update, too.....I can't tell as I don't know the software version by memory. All the other pending updates are minor PU updates and the IPMA/PSCM updates you see here are not available OTA. I don't anything to be worried about here, tbh.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1718378235724-16
jhawkbear
TX
2023 Lariat ER
Can you check mine for me again?
I'm running out of options for getting the updates. I've tried everything you can imagine.
1FTVW1EV7PWG06644
1FTVW1EV7PWG06644
OTA history is still blank.
There is nothing for you to "try". Your truck is fine; the problem lays in the OTA process which is not great.
You know, for those old enough to remember LAN parties, maybe we should arrange update parties where 10-15 people bring their trucks in and we update software all night 😀
This very thought has crossed my mind a couple times. With ProPower, could literally be done anywhere!
Inprin
Ian
Could you please check VIN 1FTVW1EV9PWG17869. Thank you
I assume you're asking about the powertrain fault message you just got? Attached is the SSM associated with the SOBDMC code is reported. Your car does not qualify for the SSM referenced the CMR code; that can be ignored.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1718463249107-jb
As far as software goes, the truck is on the latest Sync version and shows recent OTA history. You had the OBCC update for the Tesla chargers fail due to vehicle inactivity.....seems like it was parked for a few weeks in April and the truck was not turned on while the OTA trigger was active to allow it to install.
Inprin
Ian
Thanks so much. No idea what all that means yet. Not sure if it is fixable. Seems like a lot.
It's hard to tell remotely. If the powertrain fault was a one time deal, then maybe it was a glitch in the matrix. The SSM is could be cause by a loose connection or ground. If you continue to get the powertrain fault, you will have to have the dealer take a look at it.
As far as the failed update, that is nothing to worry about. They will resend it to you eventually.
Inprin
Ian
I have a deposit on this truck. Should I walk away?
You probably should have lead with that. lol Full warranty history is attached as well as the codes it has reported to the cloud for the past 60 days. It seems like the previous owner had several problems with it and traded it in due to multiple issues. As a car salesman myself, I hate doing things like this because this is also how I make a living. However, it seems like this truck may be a headache waiting to happen. While a lot of these things car be fixed with simple software updates, at this time, all the powertrain updates for the Lightnings are on hold so the dealer would not be able to apply the updates that may correct some of these problems. I would walk away.
