Failed Attempt to Charge w/A2Z Typhoon Adapter
flyct
Jerry
South Florida
'24 F-450 Platinum & '23 Ford Lightning Lariat & 2 Tesla Model Ys
Blissfully Retired
I haven’t read through all the replies. My Lightning failed initially at a compatible Tesla site. I found that when using the Tesla APP I hadn’t set up the app letting it know I had an adapter. Once I clicked YES it charged fine.
I also couldn’t use Plug and Charge with the Ford app. I didn't have the Ford update installed. It was pushed to me a few days ago.
Ford F-150 Lightning Failed Attempt to Charge w/A2Z Typhoon Adapter IMG_1480
Ford F-150 Lightning Failed Attempt to Charge w/A2Z Typhoon Adapter IMG_1461
Ford F-150 Lightning Failed Attempt to Charge w/A2Z Typhoon Adapter IMG_1463
Ford F-150 Lightning Failed Attempt to Charge w/A2Z Typhoon Adapter IMG_1462
Danface
Dan
Central Mass
2023 Lightning XLT
I had done that and I also updated the app but will double check just in case something got "outta whack". Thanks for the info!
subseavet
Herndon, VA
2023 Ford F150 Lightning Lariat Extended Range
R&D Engineer
Yes, I had the same issue. The tolerances are pretty tight on this adapter and particularly with new Tesla stations or ones that don’t get much usage, it’s very hard to get the adapter to insert properly and fully lock. I actually filed the corners off locking pin a little bit so that it would engage a little better.
The first time I used it, I almost gave up because I couldn’t get the lock to engage. It was a solid ten minutes of fiddling with it before I could get it to work.
The very same thing happened to me. Once I finally got it to engage the lock, it worked like a dream. And boy howdy, the truck charged faster than ever! Stick with it!
Refactoringdr
Don
Albion, IL
F-150 2023 Lightning Platinum (ER)
Not the official way to use one of these, but I always just plug the adapter into the truck, and the push the Tesla cable into it. I get the immediate feedback from the charging ring this way.
JIMINGA
JIM
ATLANTA
2024 LIGHTNING FLASH
SOCIAL WORKER
I’ve learned there is a very specific sequence of actions you need to do for this to work. At least in my own experience:
1. Truck off
2. Open tesla app and find the charger location and select it to begin the charging session (I don’t have plug and charge so I can’t do that yet)
3. Take the tesla charger handle off the hook and then put the A2Z adapter on nice and snug.
4. Slide the lock into place on the adapter. Again nice a snug.
5. plug the adapter into the truck and make sure the top hook clicks in fully.
charging should then start.
JIMINGA
JIM
ATLANTA
SOCIAL WORKER
This sequence of actions is EXTREMELY USEFUL, HELPFUL, and thank you MountainAlive for sharing what worked for you! I take possession of my 24' Lightning Flash tomorrow afternoon. Educating myself on charging since that's the biggest challenge!
marac243
Northern California
F150 Lightning 2023
Aw man, I'm really hoping that the group here can help me out, I'm really frustrated. Pulled the trigger on a Typhoon Pro, waited an extra two weeks from original date to actually get it, and drove my sweet truck to a compatible Tesla charger. DID NOT WORK. Sadly went away for Labor Day in my ICE vehicle. Came back, tried again using MountainAlives suggestions, DID NOT WORK. Examined the adaptor and noticed that one of the small Tesla connector pins was shorter than the other. Weird. Notified A2Z and to their credit, they overnighted me another one. This adaptor had pins the same size. "Great!", I thought, now I know why the first didn't work and I'm back in business! Went to same station and...DID NOT WORK.
I’m able to plug in just fine, the problem is that Tesla app times out and tells me “Could not make connection” once I select the charger and select “start charging”. Same with the Ford app except nothing happens once I select the charger in the app. Here's my troubleshooting so far:
  • Audible clicks and secure connections to Tesla charger and to truck
  • Continuous blue light when connected
  • Tesla charger is listed as compatible both on Tesla and Ford app
  • Software up to date
  • Tried 3 different chargers in the same station
  • Have tried every order combination I have found on this forum and Rivian’s forum’s (just in case) and made up some new ones.
I'm not sure where to go from here other than trying another Tesla station. Any ideas?
The Weatherman
Dean
South Central KY
🤔. You might get A2Z on the phone while there and see if they might talk you through it and see what happens.
VTHokies
Jason
‘23 F150 Lightning Lariat ER (Sept ‘23 build)
Believe that is part of the new instructions for the typhoon pro…
VTHokies
Jason
Did you look in the Tesla app to see if there are any outages? It’ll tell you if there are chargers that are offline…. Happened to me in Houston and took me about 4 different chargers before I got one that worked.
marac243
Northern California
F150 Lightning 2023
Thanks everyone for the suggestions. There were Tesla's using the chargers I was testing, both before I tried them and afterwards, so I don't think there was a power outage.
I contacted Ford support as I'm getting a notice on my truck that the Blue Oval network is not activated, even though I activated it a year ago and it shows active on the Ford app. I didn't think this was much of an issue as I've been charging at Electrify America just fine, but I'm covering all possibilities.
If that doesn't fix the problem I'm going to try a different Tesla station and get A2Z on the phone, as The Weatherman suggested...
duncanmaio
Duncan
Norwood, MA
It doesn't sound like this is the root of your problem, but you might try deactivating Blue Oval (in your Ford accout) and then re-enabling it (all your settings are saved). I had to do that to get Plug & Charge working, but I was always able to charge using the A2Z and the Tesla app.
marac243
Northern California
F150 Lightning 2023
Duncanmaio is the man! I deactivated and then reactivated my Blue Oval account then went back to the same Tesla station. Used the Tesla app again, picked the charger, plugged in...and got the initializing screen! Charged from 63 to 70% like a charm.
Thanks for everyone's help and suggestions. I cannot wait to get on a long road trip now. Game changer!
