Lucky Larry
- First Name
- Andrew
- Sep 20, 2022
- Calgary, AB, Canada
- 23 Lightning, RX 350, GMC SIERRA, Pontiac Solstice
I have my ford charge station pro set to use 40 amps by setting the dial inside the unit. i have a 6-50 receptacle hard wired with 6 gauge copper wire to a 50 amp breaker in my electrical panel. I then plug the FCSP into the receptacle using a 3 foot 8/3 SOOW cable with a 6-50 plug on 1 end and the other end is connected inside the FCSP. Note that i am using only brand name products in my set up.
