PreservedSwine
- Aug 5, 2023
- Fort Myers
- 2023 Lightning
I use Apple CarPlay for Nav. Does this communicate the same as using Ford Navigation when traveling to a charger as my destination? As I have come to understand- you just have to trust that the truck is preconditioning, and there is no way to manually determine if it is… or isn’t.
Took a little trip last weekend, but was only charging at ~70KW, trying to determine why so low, and if using CarPlay and Apple Maps instead of the built in navigation had anything to do with it.
Also- it was 90 degrees outside- temps on dash right in the middle.
CarPlay is aware of my battery status at all times.
Thanks.
Thanks.
