earlyadopt
Does anyone know if the XLT fast charges at a different rate than a Lariat or Flash since the battery pack is standard and not extended range?
Thanks for the update. I agree that the AC/DC is different with the SR battery compared to the LR battery, just not sure if it effected the DC/DC charging.Not that I'm aware of, the DC/DC energy flow is controlled by the system provider, it and the truck does indicate when it should be at a reduced rate.
When the 24's came out, there was a bit of confusion regarding the lowered AC/DC OBC rates translating to the DC rates of charge, Ford issued reassurances via our media contacts that the changes did not impacted the DCFC capacities.
The extended range battery can charge at a higher peak and sustained rate. It ends up being a wash when it comes to the charge time, but a charged up ER can go quite a bit farther.The larger ER battery of course takes more time to charge compared to the SR. Not sure if the curves are the same shape, but as a first order approximation, 30% more battery is going to take roughly 30% more time to fill.
Yes, the Standard Range trucks have a lower maximum charging speed (in kW) than the Extended Range trucks. Not by a lot, but the SR maxes out in the 160s kW and the ER in the 170s kW.Does anyone know if the XLT fast charges at a different rate than a Lariat or Flash since the battery pack is standard and not extended range?
15-80% on an SR takes 32 minutes, and it takes 38 minutes on an ER.Does anyone know if the XLT fast charges at a different rate than a Lariat or Flash since the battery pack is standard and not extended range?
Not sure it can on DC supercharger. Rate is going to be limited by the charger and battery temp curve.The extended range battery can charge at a higher peak and sustained rate. It ends up being a wash when it comes to the charge time, but a charged up ER can go quite a bit farther.
I also saw 175kW+ on my SR. My ER does hold a higher rate, longer, though.Not sure it can on DC supercharger. Rate is going to be limited by the charger and battery temp curve.
I have seen peak power of 175 kW on my SR. Which is the published rated peak of the ER battery as well.
Only way to know for sure is to look at what the truck is requesting via OBDII reader. I watched a couple session with mine and the truck is what lowered the amps as the SC was always providing what was being requested. I've noticed our boost period is a lot shorter in hot weather and I see it going down to 100kW vs holding at 130kW in cooler weather.Side note, I watched the charging rate drop from about 135kWH down to 93kWH over the course of about a minute using the A2Z adapter at a Telsa station. There was no one else at any of the other 11 stalls so I wondered if it was just Tesla throttling the rate?
Awesome, I'll do that. I have the OBD Link MX201 and the Car Scanner app for Android.Only way to know for sure is to look at what the truck is requesting via OBDII reader. I watched a couple session with mine and the truck is what lowered the amps as the SC was always providing what was being requested. I've noticed our boost period is a lot shorter in hot weather and I see it going down to 100kW vs holding at 130kW in cooler weather.
