Am I charging to the maximum capacity of the battery and using the buffer?
Ekiehn
Eric
2023 F-150 Lightning Latiat, 2008 Ford Explorer, 2006 Ford Escape Hybrid
There seems to be a select few of us that are having a software bug where the bms is not able to properly detect or display the true SOC. Mine is currently showing around 5-8 kWh off of true dSOC. This weekend I am doing the deep cycle bms calibration to see if that helps since I normally donā€™t go low in the pack thanks to @MickeyAO hard work.
As more and more people are posting about this happening, I suspect we will be hearing more from @Ford Motor Company about another cspā€¦.
Yes this could be a real problem.. my reported SOC is about 5% MORE than what Car Scanner is reporting.. So i tried to recalibrate charging to 100%, charging completed but car scanner only reported 96% SOC... so then real problem is when I drive it down to 10% coming back from a long trip typically for the last leg where I'll charge at home... I'm actually rolling in at 5% though the truck thinks it's at 10%... I could easily end up stranded on the road...
Grease Lightning
Johnathan
Albany, Oregon USA
2023 F-150 Lightning XLT
Exactly that is my concern too. We have already seen that situation play out as part of Out of Specā€™s issues with the press fleet lighting thatā€™s BMS got off and caused them to get a tow when they we around d 5% dSOC.
As it just started I am sure it is a bug or us needing to calibrate like Teslas have to keep the BMS balanced. I have faith @Ford Motor Company is aware or will be aware and have a solution
MADequipment
Huy
F150 Lightning Lariat Avalanche Gray
Iā€™ll hopefully report back in 9 days how the re-calibration goes. I only consume about 10% per day.
Ekiehn
Eric
I have tried to recalibrate three tumes, ran down to 25% once and about 15% another time then charged to 100% immediatly after... I also was at about 70% and charged to 100% (Helene was heading to Fl) and so far no difference.. always 4% to almost 5% reported SOC to high... I will say that after the 2nd recal when I got down to below 39% it seemed to be off only 2 to 3% to high reporting in the truck... I havnt been that low again and will be charging up to 100% again for Milton that is more of a threat this to us than Helene.... just wish my HIS was working šŸ˜ž
On the Road with Ralph
Ralph
Mojave Desert, California
2023 Ford Lightning Pro
Real estate/biz consultant
So I charged to 100% on my 2024 Lariat which reportedly has a usable capacity of 131kWh and supposedly 143 kWh of actual physical capacity. Did the software get glitchy and charge the entire capacity of the battery? My Chargepoint EVSE correlates with the Fordā€™s readings.
<sigh> Batteries are not gas tanks. Let me repeat that: BATTERIES ARE NOT GAS TANKS. In essence, they are quantum devices. There is NO direct way to know with certainty their exact state of charge; the display on the dash (or communicated to the Ford Pass app) is the truck's best estimation of the charge level based voltage and other metrics, run through an algorithm or two. Maybe one day there will be a better way to calculate the SOC, but for now, it is simply a good guess. So, in short, your obsessing over these numbers is absolutely pointless.
MADequipment
Huy
I respectfully disagree. It's an NMC battery and so the delta in voltage readings should be good enough to be within +/- 5%.
10% inaccuracy seems excessive because in the case of this vehicle, it can be the difference between being towed and not towed.
But most importantly, posting this question has educated me on the inherent inaccuracy associated with state of charge readings as I often relied on the percentage and my miles/kwh to calculate remaining range.
Grease Lightning
Johnathan
Albany, Oregon USA
Thank you for showing you have no idea what you are talking about. There is a way to determine the SOC within a tolerance. That appears to be the concern currently and the BMS is being less able to determine SOC.
Unless you have experienced this or a Ford engineer for the Lightning, please donā€™t try to dismiss and invalid others true experiences through gaslighting.
When I charge to 100% and only see 123 kWh in the ā€œtankā€ yeah thatā€™s an issue. When I am at 25% dSOC and the ā€œtankā€ only has 28 kWh (21%) yeah thatā€™s a problem, cause as MadEquipment stated, if I have to roll in to a charger thinking I have a 5% dSOC buffer that is not there would suck.
So yeah us that are living with this new hiccup have valid concerns that doesnā€™t need to be invalidated.
BTW here is screenshots of my dataā€¦.
where is your data?šŸ¤·ā€ā™‚ļø
Ford F-150 Lightning Am I charging to the maximum capacity of the battery and using the buffer? IMG_6754
Ford F-150 Lightning Am I charging to the maximum capacity of the battery and using the buffer? IMG_6769
Ford F-150 Lightning Am I charging to the maximum capacity of the battery and using the buffer? IMG_6761
Ford F-150 Lightning Am I charging to the maximum capacity of the battery and using the buffer? IMG_6770
Ralph
I have had direct experience overseeing battery engineering on contract to NASA, and for a specialized electric vehicle. I also have about 140,000 miles of experience driving electrified cars and trucks, including my 2023 Lightning.
If you actually read what I wrote, my position is absolutely true: There is no dipstick or float meter that can DIRECTLY measure the amount of energy stored in a battery. There is no tech that currently can do that. Battery management systems (BMS) provide an estimation based on INDIRECT metrics such as voltage delta, and their absolute accuracy is subject to numerous variable effects, including temperature, discharge rate/load, battery age/cycles, specific chemistry, etc. While unlikely, some corrupted code in a control module might throw off the result in a particular vehicle. And none of this addresses the possibility of a problem with the EVSE.
One other factor: Ford has tweaked its algorithms for SOC and range several times in both the Lightning and Mach-E. I'm not convinced that these adjustments were made to improve accuracy, so much as to appease drivers/customers.
In my judgment, the accuracy "problem" being discussed in this thread - which, given my daily reading of this forum, appears to not be widespread - is either a result at the edge of an explainable range of tolerance, or Ford fudging the SOC/range algorithm, or is a one-off that will be hard to duplicate. Show me similar data from a statistically significant number of different Lightnings, and I will re-evaluate my position.
Grease Lightning
Johnathan
Albany, Oregon USA
If you actually read what I wrote, what said is absolutely true: There is no dipstick or float meter that can DIRECTLY measure the amount of energy stored in a battery. There is no tech that currently can do that. Battery management systems (BMS) provide an estimation based on INDIRECT metrics such as voltage delta, and their absolute accuracy is subject to numerous variable effects, including temperature, discharge rate, battery age/cycles, specific chemistry, etc. While unlikely, some corrupted code in a control module might throw off the result in a particular vehicle.
In my judgment, the accuracy "problem" being discussed in this thread - which, given my daily reading of this forum, appears to be unique - is either a result at the edge of an explainable range of tolerance or is a one-off that will be hard to duplicate. Show me similar data from a statistically significant number of different Lightnings, and I will re-evaluate my position.
Are you one of the same NASA engineers that faked the moon landings? šŸ¤ÆšŸ¤£šŸ˜‚
Thank you for your valuable but indirect and unrelated to the Lightning, job history.
Thank you for questioning others experiences with the product of question with actual data. I can understand the desire to have a scientific relevant sampling, and I welcome your data specifically to the subject matter at hand with Fordā€™s software and the Lightning.
RaspPiDude
Ontario, Canada
2024 Flash (ER), Oxford White
Software Development, Automotive Industry
Just hopping in with an LOL at "gaslighting" in an EV forum ā˜ŗ
Suggestion: "gaslightning"!
(You're both insightful and I appreciate your perspectives and experiences.)
MickeyAO
Mickey
San Antonio Tx
Thank you for your valuable but indirect and unrelated job history.
Thank you for also gaslighting and trying to invalidate others experiences with the product of question with actual data. I welcome your data specifically to the subject matter at had with Fordā€™s software and the Lightning.
FYI, responses like this is why I no longer answer questions or post new information I uncover as we continue to test the SKOne E80.5 cell (used in all of our Lightnings).
It seems that those who can see some data from the CAN, with no knowledge of how the data is generated, know SO MUCH more then those of us who see actual data in ESS (Energy Storage Systems) and have learned over the years what it actually means.
I will say that I am not happy with the performance of the E80.5 in our testing, but I won't bother to elaborate on why because I'm sure someone on this forum will tell me why it doesn't matter. I will drop this one bread crumb for all those who know more about the cells then me based on anecdotal, indirect information; If you must store the cells at 45C, make sure you are no lower than 80% SOC (actual capacity). This goes against most everything I have posted before, but there is actual data on why I say this.
Grease Lightning
Johnathan
Albany, Oregon USA
I will say that I am not happy with the performance of the E80.5 in our testing, but I won't bother to elaborate on why because I'm sure someone on this forum will tell me why it doesn't matter. I will drop this one bread crumb for all those who know more about the cells then me based on anecdotal, indirect information; If you must store the cells at 45C, make sure you are at 80% SOC (actual capacity). This goes against most everything I have posted before, but there is actual data on why I say this.
Thank Mickey, me and many on this forum value your hard work and knowledge. I appreciate you taking the time to comment as your direct experience was what I was referring to as you have alluded many times on here that our cells act ā€œdifferentā€, and that data is invaluable.
Thank you once again for spending your time doing all that research, but also using that experience with your own Lightning to help provide guidance on what we may expect to see from our own lightnings. šŸ™
Grease Lightning
Johnathan
Albany, Oregon USA
You may be correct here. Marketing typically wins over science and accuracy šŸ¤·ā€ā™‚ļø
I hope it doesnā€™t bit them in the rear with people getting stranded or worse battery warranty claims if the software makes degradation look worse then it is. šŸ˜±
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Here is a perfect example of why past EV battery experience, even of those with a great deal of first hand battery demo experience, must be careful applying it to new batteries without first seeing the results of long term extensive testing.
Mickey about a year ago, before ALL of his testing of our cells were very advanced, said just about the opposite because "the degradation after 8 weeks is amazing" when stored at 80% in temps above 131 F.
For our friends in the HOT areas that plan to keep their truck for awhile, take notice. If your truck is parked (stored he said) such that the battery will reach 113 F, "make sure you are no lower than 80% SOC (actual)." Now, 113 F air temp is different than 113 F for the battery, but over asphalt .... who knows, it could reach those numbers.
I am glad we have that 8 year warranty.
Grease Lightning
Johnathan
Albany, Oregon USA
Well was finally able to drain the battery and charge it back up and too balance it. As I was doing some of this while out of town, please ignore the 69 hours that it took as I was modulating my charger remotely to have it finish when I was home.
So drained the truck down to 10% dSOC that was showing 12 kWh in the tank.
Ford F-150 Lightning Am I charging to the maximum capacity of the battery and using the buffer? IMG_6902
Started it at around 10 amps 240v to stretch it to when I was anticipating returning from an out of town trip.
My charger said it was providing power for 68:54 and provided 147.288 kWh.
Ford F-150 Lightning Am I charging to the maximum capacity of the battery and using the buffer? IMG_6937
My FordPass notes shows 69 hours and the truck received 131.6 kWh of power over that time.
Ford F-150 Lightning Am I charging to the maximum capacity of the battery and using the buffer? IMG_6936
From Car Scanner the dSOC is showing 100% and shows only 128.56 kWh in the battery @ 66 deg F.
Ford F-150 Lightning Am I charging to the maximum capacity of the battery and using the buffer? IMG_6939
also looks like the module variation was cut in half.
Battery health is still showing 99.5% @ 17.5 month.
So wish it didnā€™t take as long to actually do it, but battery is closer to what I have seen in the past and ā€œfoundā€ some of the previous lost kWh noted by me and others.
