Automatic speed adjustment for Speed Limit Sign
Ishkatan
Adam
Monrovia, Md
2023 F150 Lightning Lariat ER =RAe (Range Anxiety)
Old
I found a new (to me) setting that changes my speed when the truck sees a speed sign. Set it to 5 mph over the speed limit sign and it does just that. I wish it was a percentage since 30 in a 25 is much different than 70 in a 65 zone. Also annoying and requires gas pedal or cruise control (+/-) override when the speed limit on a major road (N.C.) drops from 50 to 30 and then back to 50 within a couple thousand feet and traffic does not change speed. But great for avoiding missed speed limit signs.
Still have to watch it around schools. I am not sure if it does nor does not cognize school speed limit signs and correlates with time of day. Seemed a bit uneven with those when I came across some. The computer is still training me.
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
I wash going down the interstate once and looked down and the dash said the speed limit was 25. I'm glad I didn't have that setting on.
Webbo85
Marc
Glenmoore, PA
2023 F150 Lightning Lariat ER, 2002 Jeep Wrangler
Mech Engineer
A lot of people who have had the truck for while have turned this feature off. Most have found that it will pick up odd signs along the road that it mistakes for speed limit signs and will change speed drastically. It doesn't appear to reference the road information so if it see's a route sign for 85 it will assume that's the new speed limit and accelerate to that speed. Worse it will slow down very quickly if it mistakes a sign on the highway. Ended up being more of a hassle than it was worth personally.
I'm in the switched OFF camp, after a few exhilarating decelerations on I-495
I also turned it off. It reads the signs on the service roads while you’re on a freeway. It also uses a database that has errors. There’s a street in my city with a 30 MPH speed limit and the truck thinks it’s 70!
BennyTheBeaver
Should we be using any form of speed assist automation or cruise control in a school zone? ;)
Steely
SE Mass
2022 Lightning Lariat
I like how the gauge cluster reacts when this feature is on, and cruise control is not currently enabled. It puts a hash mark on the gauge where the speed limit is dynamically. I wish i could get it to do that all the time.
I also wish there was a way to set a dead band where the system wouldn't adjust the speed, as it currently is it just goes directly to that +- value you set. It might also help with the incorrect speeds if there was a way to set it to be more leisurely with its speed adjustments. I find it very aggressive adjusting to a 5mph change in 1/2 a second or less.
Oh yea, that said, I also have the feature off.
CC has saved my bacon several times I'm fully engaged in driving and looking for kiddies, but I set it at 20 mph, saves me with my lead footed tendencies, of course we should always be on the ready to mash that brake should a kiddie dart into traffic. I travel through several RI towns that are employing speeding citation cameras in school zones.
