user-name-required
Hello
Have a '24 Flash trim in my driveway at the moment on a 2 day test from a local dealer, and I took it to a Shell 180kw fast charger to see how it does. I am not a lightning owner at the moment obviously, so if I am missing anything please keep that in mind that I can't find concrete info on every topic before posting....That out of the way, here are the details
Has anyone seen this before? Is this something wrong with the charging of the truck? I notified the dealer, but as is common with EVs and dealerships, I expect nothing more than a shrug from them about what could have caused this.
I won't be able to get the charge down low enough to try and replicate the test again, in the time I have left with the vehicle unfortunately. So, hoping forum members can help me out here....
Trying to take advantage of 0% financing, but this charging thing has me a bit spooked.
Thanks
T
- Couldn't use the Ford native navigation system to pick the chargers. I think because it is a test drive or something? Used the Android Auto to select the charger as a destination
- Arrived at 43%, after about 230kms of various driving and towing tests, battery temp guages in top of cluster were in the mid of their desired temp ranges.
- Charged from 43-60% at a steady ~145kw.
- Never saw the "surge" up to 180 that I expected from watching the State of Charge youtube channel and his charging curves (see link to his article)
- BUT, a steady 145 is ok I suppose.
- From 60% - 79%, was steady at 115kw
- At 80% - 85%, dropped to about 55kw avg
- BUT....from 85% - 90%, something weird happened
- the charge rate on the driver dash was all over the map, changing every few seconds, and ranging from single digits kw up to the 60's indicated charge speed
- The display on the charger also fluctuated, but much less frequently compared to the dash display.
- See images attached for some of the variances
Thanks
T
