FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62
Ok I assumed you knew exactly what you are doing, but couldn't find anything matching the previous screenshots. I realize those were with the old Fordpass app which no longer has that data. That is indeed a wierd bug, but has it caused any functionality issues?
Functionally she charges perfectly fine, hopefully I'm not missing out when the next true update version comes out, as of now I actually had this version with full string of digits, then a proposed update popped up many months ago resulting in this corruption.
So far I do not think Siemens has issued any firmware/software updates, I'm relying on others to report if/when that happens, hoping my unit heals this flaw.
Scorpio3d
SS/IBA car wash owner
Mine works fine charges the truck like it should just reports the data wrong!
Scorpio3d
Did you perform a power cycle on the FCSP?
@Ford Motor Company PLEASE have someone look at the database which stores our charging history data, I suspect a process corruption has occured after 10/13/2024.
Yes, but I am going to repeat in the morning, as the units do a phone home sometime after midnight.
Scorpio3d
I just did mine. I will see what happens tonight.
Scorpio3d
I'm familiar with how to pull the SW version, here is a snapshot that I just pulled from the FCSP setup app by "Manage Settings".
Interstingling Fordpass v5.6.0 has hidden this value formerly found in the Advanced > Charge Station Setting display.
I think you are both android I am iOS. Mine is showing the full software version numbers not a bunch of zeros, of course I did not check it before I did the power cycling earlier?
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 IMG_1111
Correct, I'm using an Android install of the FCSP Set-up App and Fordpass app.
I believe other members on Android are getting the full software version number, my situation is unique.
Jim Lewis
San Antonio, TX
Scorpio3d
No improvements with this mornings restart. Data from departure time conditioning event while plugged in still corrupted by 1000th the true value.
@Ford Motor Company your database is garbage
Same with mine!
Another weird thing which is probably an Apple thing is when I take a screenshot photo. It also includes a copy of my home screen, but I was sitting in the truck today so it included what is on the screen of my truck from CarPlay. Very weird!
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 IMG_1114
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 IMG_1115
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 IMG_1116
Ffxdude
22 Lightning Lariat ER
I’m seeing the same junk since 13-Oct.
Same here. Seems to go back to 10/14 for me. This is why it would be nice to be able to export our charging history.
That makes sense, actually 10/13 was my last good charging data point, but I'm generally only charging weekly except when I am doing some testing. Yesterdays charge session continues with bad data.
I'm hoping the engineers who manage the database receive my APP reports and thee fix what is affecting this on the server side of the system. Maybe @Gimme_my_MME could jingle a few bells for us!?
Then they need to go back and perfect the flawed information from 10/14 forward to the repair point.
