OIF_VETERAN04
2023 F150 Regular Cab XLT
@ZSC100
I got everything done but now my truck has errors on the screen for per-collision assist not available and service AdvanceTrac.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
I cleared the codes. But it just keeps coming back with ABS codes. I checked the forscan that was done to the ABS but it's correct.
Are you getting the CCM to show up as a working module? Have you programmed the VIN into it correctly?
If so, revert all your module back (except the CCM) and return your truck to factory AB. Then make IMPA changes only first and clear all DTC's.
OIF_VETERAN04
I reverted everything back to factory ab and am still getting ABS DTC's.
I'm going to have to try again tomorrow to forscan everything. My laptop is dead lol
tannerk89
Tanner
Roanoke, VA
2023 F-150 Lightning Pro ER
Automotive Engineer/Product Owner/Project Manager
Might want to double check wiring changes. Missing a connection somewhere could cause an error like that.
OIF_VETERAN04
I quadruple checked the wiring harness I made as I was doing it and after I installed it. Cause I was paranoid about putting the wrong wire in the wrong place.
So I know that is all good. I'm sure I made a mistake doing the forscan. So I will redo it all, now that everything is back to factory ab and all errors have disappeared.
Thank you for your insight. I do appreciate all thoughts and opinions.
Silenze
Wi
You might want to try the gas F-150 forum. The changes here are for the electric F-150
OIF_VETERAN04
I will definitely do that. I know this is for the lightning. So as I went through the changes I checked the spreadsheet. But I definitely did enter the wrong change somewhere.
Thank you for your help and thoughts on my issue.
