Ford Pass App Charge Station Pro Amp Adjustment Setting Useless
IWIRE
Nick
2023 F-150 Lightning Lariat
Electrical Consultant
I asked Ford's EV Charging department why they have a setting in the Ford Pass App that lets you adjust the Charge Station Pro amp draw from 6 amps to the maximum you have allowed per your circuit installation, which in my case is 80 amps, as I installed it on a 100-amp circuit. They said the app used to have that functionality, but it no longer is available in the app, and yet it remains, and I asked why, but no answer. Ford should reactivate that functionality as it is a lot easier to change the amp output in the app than it is to turn off the power, remove the faceplate, then take out 9 screws in the cover, only to have to reverse that procedure, just to turn the dial to a different setting. If Ford could please make the functionality in the app work again ASAP, if not they should remove that option from the app until they can, and then add it back to the app as it is a great function, and in my case would be frequently used.
BSull
Robert
Mesa, AZ
Corvette, F150 Lighnting, Mercedes GLC300
Are you saying the ability to change the amperage in the Charge Station app, available through FordPass is non-functional?
As far as I know, there is no direct way to change amperage in FordPass.
IWIRE
Nick
Yes through the app it has a slider bar to change amps, but it does not work. Photos attached. Energy tab at bottom, then charge station, then settings, then edit max charge current.
Ford F-150 Lightning Ford Pass App Charge Station Pro Amp Adjustment Setting Useless IMG_0469
Ford F-150 Lightning Ford Pass App Charge Station Pro Amp Adjustment Setting Useless IMG_0468
Ford F-150 Lightning Ford Pass App Charge Station Pro Amp Adjustment Setting Useless IMG_0466
Ford F-150 Lightning Ford Pass App Charge Station Pro Amp Adjustment Setting Useless IMG_0467
It's been problematic form many months, even in older versions of FordPass.
I'd love for them to fix it!
IWIRE
Nick
Never got to get my app to change anything.
I would argue it never worked at all. Even when it did "work" it took many requests to actually change the charge rate.
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
Well at least you have an app.
Us with the Juicebox charger now have no app at all.
Rick
BSull
Robert
Mesa, AZ
Yeah but slider is in the charge station app not directly in FordPass. Picky I know!
IWIRE
Nick
Rick
I am looking for an EV Charger that uses my excess solar in real time to charge my EV. The Enphase IQ does it in 25% increments adjusted every 15 minutes, but I want something more responsive, and with the FordPass App if it worked I could tweak it to be close most if the time.
HEADS UP
Forum wide we're experiencing an issue with error messages when submitting a post, DO NOT resubmit, likely 99% that your post processed, refresh the browser to see your comment posted.
If you hit the [Post Reply] again and again and again, it's cause multiples that I need to clean up.
PJnc284
Garner, NC
2023 Ford F150 Lightning
Gotta do a dance, stand on your head, and cross your fingers and toes. Then flip a coin and maybe it'll work.
I think Emporia has what you’re looking for.
