LSP
Scott
Orange County, CA
Lightning Lariat ER, Audi e-Tron
I'm considering purchasing a Lightning, but my garage is a few inches too small. I could park it on the pad next to the garage and have the charger installed outside, but I live in MN. There will be snow to deal with. I wonder if anyone else has had to do this. Any comments on the experience?
Has anyone found a way to extend the garage that doesn't cost a ton of money? The contractor I talked to said that by the time he extends and blends in new construction, I might as well just tear down the garage and build a new one.
I'm trying to decide if I should wait for a smaller truck to come out, but I could use the Lightning next summer for powering a job site for a cabin build.
I live in Southern California but I have to park my Lightning outside of the garage. FYI, the cable for the Ford Charge Station Pro is approximately 20 feet long and so I can easily run it under my garage door to my truck.
ZSLC
Zach
Salt Lake City, UT
F-150 Lariat Extended
I live in Utah, up a canyon. We get snow, lots of snow.
I park outside and mostly use the "portable" charger on a beefy 220 extension cord.
My opinion is, it's a truck, it can handle being left out in the cold.
Athrun88
Toronto, Ontario, Canada
Great to hear that there are no real adverse effects from parking/charging outside in the cold. I'm in the same situation, garage is too small to accommodate the Lightning. Didn't think there would be issues but always good to get first hand experiences.
It’s 24’ including the handle.
ChrisCon
The Hamptons, NY
I live in New York . My truck has never been inside a garage . Two years later , my charge station pro works perfectly . Snow, sleet, ice= no problems. Remember to set departure times on your truck so your battery is warm in the winter to maximize range. Everyone forgets this step and it's the most important thing you can do .. even if you set a departure time an hour before you leave , it's better than nothing.
Texas Dan
Daniel
'04 Envoy XL 4WD, '15 Fusion Energi, '19 Niro EV
There are a lot of reasons to park a Lightning in a garage besides keeping it out of the snow. In Texas one of our big concerns is hail damage. That being said, we use our garage primarily for storage and as a work shop and there hasn’t been a car parked in the garage regularly for two decades.
I do want to park my Lightning in there but first I have to find a place for all the junk. Even with all the junk out of the garage it’s going to be a very tight fit for the Lightning. The cord on my ChargeStation Pro inside the garage going under the garage door easily reaches my Lightning outside the garage so there is no great urgency for me to get my Lightning inside the garage.
Newton
WA State
You will love the remote climate control ability (although Ford should let you leave it on longer). No fuss, no smell, just a warm car when you need it.
I do wish I could set a minimum temperature when plugged in, at home I don’t care about range but I do care about the water bottles freezing.
Warp Asylum
Austin, TX
2022 F-150 Lightning Lariat ER, 2023 Mach-E GTPE
In cold climates and particularly when parked outside, try to keep the truck plugged in at all times. It will use shore power to keep the battery warm to prevent long term degradation (as best it can). It's not just for departure times/preconditioning.
Texas Dan
Daniel
I just got a new insulated door. The new garage door is thinner than the old door and gives me about two inches more clearance in my garage. I’m looking forward now to clearing my garage out to see if I can get my Lightning in there.
Just to give you guys some numbers, the internet says the Lightning has a length of 232.7 inches or 19’-4.7”. I just measured a clearance of 19’-7” in my garage. If the internet information is correct I should be good.
