Powertrain Malfunction/ Reduced Power
Turbo_T
2024 Lightning Flash
Check my spreadsheet linked in my signature below and do a find for "57%" and you can see a number of reports. For some it is a bad cell in a battery module, and for others it can be a different cause. Most of these listed in the main thread for PM/RP since 2022. https://www.f150lightningforum.com/forum/threads/powertrain-malfunction-reduced-power.12873/
@powercatnewt , what is your build date shown on the drivers door sticker? miles?
oh man, if I had seen this spreadsheet before buying I would of ran for the hills. Purchased a 24 Flash 2 days ago and "Powertrain malfunction" has appeared on my dash. It doesn't appear that I have reduced power but I'm also still learning all the displays. My gear shift also does not fold down so I'm hoping it's just that?
The Weatherman
Dean
South Central KY
Chances are good it’s not a battery module. Nearly if not all that have had that failure have seen power reductions down in the 60-50% range.
