BATTERY PERCENTAGES NOT MATCHING
GoodSam
Good
occupying space
I believe you need to set your target SOC to 100% for the balancing to work best. Most of the balancing happens when the highest module is above 95% SOC.
Any official or unofficial references to this thought of the need to go to 100%?
GoodSam
Good
occupying space
Build Date top of sticker inside driver's door b pillar?
@Wonko , @Psmith7279
for my tracking spreadsheet - link in my signature below:
Adventureboy
It is my understanding there is a technical bulletin supporting the balancing procedure. I do not have the official bulletin however, here are the full unofficial procedures.
Procedure (NMC packs):
  1. Charge the vehicle to your normal level (e.g. 90%).
  2. Drive the vehicle (without charging) until the battery is down to 5% or less.
  3. Park the vehicle and let the battery rest for at least 5 hours (preferably overnight)
  4. Level 2 charge all the way to 100% in one session without interruption.
  5. Leave the vehicle plugged in and let the battery rest for 3+ hours after 100% is reached.
  6. (Optional) With a scan tool, read the kWh to empty and state of health parameters.
  7. Drive without charging until battery is below 50% (10% recommended)
  8. Charge the vehicle back up to your normal level.
  9. Repeat if desired.
The OP has had a battery module replaced so it may take more than one iteration of the procedure above to balance the pack.
Balancing is more important for LFP batteries, but it is still needed on NMC batteries occasionally. Try this - watch your charge when you get to 99% and see how long it takes to get from 99% to 100%. This is where the bulk of the balancing happens and if you haven't done it for a while, it can take several hours to bring all modules and each individual cell to full 100% SOC and actually show 100% SOC on the gauge.
Nearly 2 years on my 2023 Lightning ER and my pack SOH is still 100% so the monthly 100% SOC charge is working. I have also built my own LFP packs and configured the BMS myself so I have a pretty good understanding of how they work. It is very difficult to balance the cells/modules below true 90% SOC due to the very low voltage difference below that. Ford protects the top 7-8% SOC so we need to be at 100% gauge SOC for the balancing to work effectively. The top balance is needed for all Lithium battery chemistries occasionally.
It can take up to 3 hours or even longer to go from 99% to 100% as it balances all cells/modules.
Sorry for confusing the discussion about getting a pack back in line, vs. an occasional charge to 100% that is otherwise healthy.
I was not aware of the details outlined in post 18.
