shelnian
They closed the plant down so there's probably no one to update the order database. Did they give you an estimated delivery date?
Looks like it's built but still at the assembly plant. I don't know if they are doing extra QC on new units, but it has the bedliner installed. Just needs to be shipped.UPDATE 12/14!! Well, tomorrow will begin month #2 without a truck. Playing phone tag with servicing dealer but to my knowledge the original truck is not fixed yet and we are not pursuing.
As for the replacement truck, according to Ford there were none on the east coast even though I could see a couple on the build website and on dealer websites (I didn't call to verify) but apparently they found a truck at some unknown RDC that is in process of being routed to the selling dealer RDC and then to the dealership. Just got a VIN yesterday and I requested a copy of the sticker as it was not available on any of the Ford sticker lookups. Was told it is a freshly built truck but we all know the plant has been closed for a month. When I put the order # and VIN in from the sticker, I got the below. So my concern is why is the last update on this vehicle 10/17 and it looks like the process was stopped as if Ford pulled it off the line or something. Anyone with ideas?
Thank you very much for this and the sticker. The one I was provided is a scanned version that was not easily readable.Looks like it's built but still at the assembly plant. I don't know if they are doing extra QC on new units, but it has the bedliner installed. Just needs to be shipped.
This just happened to me! I stopped in a remote location to ride my bike and when I came back, the symbol shows, and it won’t start at all. Now I’m stuck!The red battery symbol typically means you are in accessory mode, confirmed by that popup message. This occurs when you don't depress the brake pedal when pressing the Start button.
I wonder if there is an error in the brake pedal sensor area - maybe it's not seeing the brake pedal and throwing the Stop Safely message. Could look under the dash to make sure nothing came disconnected.
Check your Software updates to see if something was just installed while you were away.This just happened to me! I stopped in a remote location to ride my bike and when I came back, the symbol shows, and it won’t start at all. Now I’m stuck!
Thanks, I called my dealer and we decided just to have it towed in via Ford roadside assistance. What a bummer! I had some updates done by the local dealership about two weeks ago. I wonder if that has anything to do with it? I’ve never had any problems whatsoever with my truck.Check your Software updates to see if something was just installed while you were away.
If so, let it sit for 15 minutes and try starting.
Good luck, I'm interested in hearing what they find.Thanks, I called my dealer and we decided just to have it towed in via Ford roadside assistance. What a bummer! I had some updates done by the local dealership about two weeks ago. I wonder if that has anything to do with it? I’ve never had any problems whatsoever with my truck.
By the way-24,000 miles no problems.Good luck, I'm interested in hearing what they find.
