KennyB123
- First Name
- Ken
- Jan 23, 2022
- Detroit, MI
- 2023 Ford F150 Lightning Lariat ER
2023 Lariat ER - I was lucky enough to get the update on the first day they started sending it out. I didn't get a chance to really test it until a few days ago on a 300 mile road trip between the Detroit area and the Indianapolis area.
Living north of Detroit, I took I-94 south to I-75, to the Ohio Turnpike where I had my only charge of the trip. Then eventually to I-69 south.
Here are some of my observations -
- On I-94 before the update, BC 1.0 would disconnect on EVERY curve, and even randomly if I drove in the left most lane with a yellow line on the left. On this trip, my mind was blown. Not a single disconnection through that entire segment, and the truck rarely even slowed down during those steep curves. (74mph)
- On all highways, lane changes were great. It actually takes stress away because I quickly learned to fully trust it's own blind spot monitoring before auto lane changing. I just clicked the blinker and let it happen. It takes anywhere from 7 to 9 turn signal activations to finish the lane change, and yes, the rear turn signal light does light up for all of them, even the 3 or so blinks that occur before it starts to move lanes.
- My first BC disconnection was when going through the EZ Pass fast lane camera area. After it did it on a second EZ Pass lane, I realized it was intended behavior. I'm not sure why, but it turned back on immediately.
- A couple lane change observations - on BC 1.0, if you touch the wheel to change lanes, BC would disconnect. Now, you can "assist" the lane change by beginning the lane change earlier than it would on its own. BC remains engaged and happy. One time, I accelerated ahead of a car while manually lane changing, hitting 81 mph, and BC still didn't skip a beat. Amazing.
- I had one emergency red box exclamation point moment when I only had a minor required deceleration, and yet BC remained engaged and happy after it was over in around 2 seconds.
- The feature where the truck can get over on the opposite edge of the lane when passing a large vehicle like a semi truck was hit or miss. But, when it worked, it brought a smile to my face. I think it might even get to the right edge of the lane when being passed on the left, which is great as well.
