Heater Recall with no solution for nearly 6 weeks - thoughts
Driving to Nashville from Sarasota, FL i found out i have no heat....
I'll just watch what's going on with this recall once I'm back home. I rarely need heat.
Love the truck but Ford is terrible at being forthcoming about issues. Just tell the truth the cover up is worse than the crime or is the crime.
Get it checked out when your road trip is over, with a '23 your PTC or a diverter valve may be malfunctioning.
Ron Roman
Ron
Sarasota Fl
2023 ford lightning lariat
Caretaker of property
789 trucks missed a solder joint. Recall 23C32.
Truck has a heat pump.
Sarasota Ford drop off on Jan 27th i get a loaner. Approx 3 days
Ron Roman
Ron
Sarasota Fl
Also told the problem effects 07/23 to 12/23 builds.....Oops mine is 05/23.
Told mine wasn't part of the recall....or did you miss several more months with this problem?
I still have confidence in Ford.
I'll let you know.
