Mike G
- First Name
- Mike
- Jan 6, 2022
- N. AL, USA
- 2022 F-150 Lightning, 2023(J1) Mach-E GT-PE
I know that the VCM 3 is a lot faster than a VCM 2 or a comparable J2534 device like the Mongoose + Ford, or Bosch Master Tech. I believe what they are trying to tell the techs is that if you have a VCM 3 in the shop, put down the VCM 2, and go get the VCM 3 out of the cabinet because this will be faster using that. I don't think the issue is whether or not the success rate of the update will be impacted....it's just a lot faster.I saw that, but as far as software updates go you'd think it's a matter of it either works or it doesn't and not that "best results" could mean we'll brick certain functionality if you don't use a VCM3.
