Tesla charging giving 175kwh
Canuck5902
Jared
23 lightning
Contractor
My first Tesla charger gave me 120kwh on my 23 sr. After a dealership software update I then got 175kwh. I am under the impression that 125 should be max. Should I be concerned? Anybody else seeing these numbers?
tkm7501
Taylor
Beebe, AR
F-150 Lightning Lariat ER Max Tow, Tech Package
Store Manager
Completely normal. Iā€™ve gotten 180 Iā€™ve seen some at 190. It will pull that for a few minutes then go down as the SOC gets higher.
Ford F-150 Lightning Tesla charging giving 175kwh IMG_1256
175 on an SR?! Wow, that's faster than I have seen with my ER.
I don't think there really is a "max" charge speed number. A wide variety of factors contribute to how fast the battery can absorb energy. This includes temp, charge level, etc. There are also a variety of little things that may contribute too, like cable temp, battery age, cell voltage variation, cooling system temp, charger temp, etc. If it happens it's probably just all those things coming together.
tkm7501
Taylor
Beebe, AR
Store Manager
I didnā€™t even see the SR part. Lord I need to go to sleep šŸ˜‚ hey if the truck is asking for it. Let it take it. Batteries are the same. One is just bigger. I myself have the ER. Not sure about the cables and stuff but any thermal issues would(should) automatically limit it for heating issues.
scoobybri
Virginia, USA
2023 Lightning XLT w/Max Tow and TT Packs
This past weekend charging at a Supercharger in 25F weather with the truck preconditioning prior to charging...normal.
Ford F-150 Lightning Tesla charging giving 175kwh 1000000598
Canuck5902
Jared
23 lightning
Contractor
That is identical to my scenario right down to the price. Except mine was in Canadian dollars lol.
Calvin H-C
Calvin
State of Charge has this video:
In it, he describes how Ford implements a "max power boost" (his term) period where the charge rate will go above the usual rating for about 4 to 6 minutes, depending on battery temperature. In the video, it climbs to just above 160 kW.
One benefit of this is that if you find yourself only needing a small top-up to get you to your destination, this can cut your time needed so you can get back on the road. In the video, he shows how this will get you about an extra 30 miles of highway driving with a five minute stop.
NCMike
Raleigh, NC
2022 Red Lariat Lightning
How do you confirm the truck is pre condition when going to a supercharger? Are you putting a nearby charger in the nav?
Canuck5902
Jared
23 lightning
Contractor
That is what I did. I could not get many chargers listed directly through the truck so I set the destination in the ford app and it transferred to Apple Maps.
I was able to verify it with the car scanner. Battery temp rose.
scoobybri
Virginia, USA
Yup. I put the Tesla Supercharger in Google Maps as my destination about an hour away. Got 170+ kWh instantly on a 25F day with 10F wind chill. There's no way it would have been so fast if it wasn't preconditioned. This confirmed to me that the Google Map integration with the Lightning does indeed do what they says it is supposed to do. The destination charge level was very accurate as well. No need for crappy Ford Nav to precondition or let me know what my charge will be during the drive.
NCMike
Raleigh, NC
Wow, I wasn't aware that google or apple maps could trigger a precondition. That's good to know.
NCMike
Raleigh, NC
Only Google Maps on Android Auto. Apple Maps doesn't precondition for now anyways.
Ok, that makes more since cause I use car play and havenā€™t seen any indications of preconditioning yet outside of the ford nav.
electricpig
Tim
Northwest Arkansas
F150 Lightning, Tesla Y
I have the same to say about using Google maps routing. This past weekend, I tested it on a longer day trip. It seemed to account for wind, elevation, and temperature effects. In fact it was a little conservative resulting in a arrival with a few percent more than estimated. Like partly due to driving a bit under the speed limit on the Interstate.
