Job 2 Order Guide and changes
Flash and optional PRO extended range batteries with less usable capacity
Flash losing standard charging pad and tailgate step
Platinum has an optional Dark Elements package
Space White paint is optional, Avalanche is deleted
Ford F-150 Lightning Job 2 Order Guide and changes job2 1
Ford F-150 Lightning Job 2 Order Guide and changes job 2
Ford F-150 Lightning Job 2 Order Guide and changes job2 3
Ford F-150 Lightning Job 2 Order Guide and changes job2 4
mrau
23 Lariat⚡ER
Seems there might be only 8 battery modules in 2025 Flash ER instead of the 9 modules in Lariat ER.
Also see that spare tire is an option now. Tire sealant is standard. Ughh.
broncoaz
Cape Cod, MA
A full size spare tire on a truck is not negotiable. Bad shit happens to trucks on job sites, tires get destroyed. I’m annoyed the spare on my 2024 Flash is marked “Temporary”.
I’m glad I bought the 2024 before they removed features.
biers
Thomas
SW Washington
eGolf
Wonder if same number of modules but rather the 122 kWh packs are LFP chemistry.
astrand1
Alex
Studio truck driver
I’m glad I found a left over 23lariat. They just keep chipping away. 🙄
While not entirely improbable, I believe this is a cost cutting move. The usable capacity on the Mach-E Premium and Select Extended Range batteries are being reduced too, and are keeping their existing chemistries.
Not only that, the Marshall plant that will be producing LFP batteries with licensed CATL processes doesn't come online until 2026.
SmoothJ
New Jersey
2022 F150 Lightning
Why would they lower the kWh? I know you say cost cutting, but it doesn't make sense when you have other manufacturers possibly have more range due to a larger battery pack.
Unless, its the same pack, however they want to charge you a bit more for the extra amount. Not unlike what Tesla did.
"122 kWh Usable Capacity Extended Range Battery"
NikonJim
2024 F-150 Lightning Flash
Will flash EPA range drop to 300 miles?
I work for Ford. Everything lately at work revolves around cost cutting. The T3 Lightning has been delayed again. The 100% redesigned ICE F-150 is being pushed back another model year. Management is fixated on how their bonuses are being affected. Maintenance on machinery is being pushed out and delayed or skipped entirely. Headcount is constantly being examined. Overtime has been cut.
My only guess is cost cutting. Not saying that is it, but that is what I see.
broncoaz
Cape Cod, MA
It seems like the auto market and other markets are at a precipices of disaster. The next couple of years will be interesting.
SmoothJ
New Jersey
2022 F150 Lightning
Sounds like they want to make their books look better for the investors before the end of the year.
So in 2024 there was supposed to be a late-availability Platinum option called Platinum Black Package. It never materialized (along with the LFP battery for Pro/XLT). This Dark Elements Package looks to be another attempt. Has some of the same options:
2024
Ford F-150 Lightning Job 2 Order Guide and changes 1736708466023-sq
(Note for 2025, they Power Running Boards with Black Accent are a separate option).
