Ford Lightning with an onboard power system that provides a 240V output, tw0 110vac 180 degree?
Devereuxstreet
Pittsboro
Tesla MYLR, Toyota Tundra
I just purchased a Ford Lightning with an onboard power system that provides a 240V output. But I will get car next week, Since my well water pump at home operates on 240V, My question is: Is the 240V live wire equivalent to 110V AC relative to ground, or can I directly send 240V to my home’s electrical system? I don't need send another cable - 120v to home again I don’t want to use Ford's Intelligent Backup Power system because it’s too expensive. I also have solar panels, a solar system, and a gas generator. But my solar diverter is 220vac. Not two 110vac, 180 degree. My goal is to disconnect from the Hydro One power grid during the summer due to high electricity transfer fees, which are 0.15/kWh and sometimes transfer fee even 0.20/kWh. Is it possible to do this?"
Effonefiddy Lightning
Alfred
Excuse me if this is redundant but I recently had a transfer switch installed with the 30A plug. If I were to cut off the ground wire from the cable to make it work with my truck, what is the danger in doing that. I've read peoples post on doing this so I just want some clarifications as to weather or not this a bad idea. Also I live in California. Not sure if other state wire home differently.
Runaway Tractor
Yes
If your transfer switch also transfers the neutral, then there is no need.
If your transfer switch does not transfer the neutral, then you have the usual problem with the GFCI tripping. Lifting the ground on the house end of the cable at the generator inlet receptacle creates no danger or safety hazard. None. Zero. The only hazard is the code Nazis trying to throw books at you. Every circuit breaker, GFCI, AFCI, and other existing protection devices will all still work. There is no lost or disabled functionality that existed in the normal power configuration. The ground wire in your generator cable is intact and protecting the cable itself. Like if someone ran it over with a lawn mower or water got in it.
It doesn't meet perfect code requirements. But this is temporary, safe, emergency power.
Al_V
Allen
Canton, Ohio
BTW, I laugh when I see people complain about electricity costs like C$0.15/kWH. Most people in California do not get that even during the lowest cost TOU period. Frankly, I don't see how you get any meaning ROI with solar given that level of electricity cost.
The OP stated that the "electricity transfer fees, which are 0.15/kWh and sometimes transfer fee even 0.20/kWh."
I'm pretty sure that is only a very small portion of the total he pays for power.
My bill from AEP in NE Ohio includes charges for Transmission, Distribution, generation, and a monthly "customer charge" of $10.
Generation, or "supplier" charges are about half of my total bill, transmission and distribution are approximately %25 each.
In my case the total is about .17/per KWh, so the OP may be paying 2-3 times the "transfer fee" for the total bill.
Danface
Dan
Central Mass
2023 Lightning XLT
Well, I had a generator plug and a simple main safety added, but when I connected the truck 220v to the house, the truck GFI tripped. After much internet searching, I finally disconnected the ground wire at the generator plug and it all works! I’m sure someone will be rolling their eyes at my actions, but . . . It works. All other options would have cost thousands.
In most states it's OK to not connect the ground when the generator is not permanent
Peng
Peng
2024 Ford Lightning
Because this is a technical discussion, like backup power, if we were just using power from the grid, we wouldn't need to discuss it.
my basement 200A panel and ATS (automatic transfer switch for gas generator 7KW)
Ford F-150 Lightning Ford Lightning with an onboard power system that provides a 240V output, tw0 110vac 180 degree? 1736723711394-i
Peng
Peng
2024 Ford Lightning
Outside house solar controller and another panel
Ford F-150 Lightning Ford Lightning with an onboard power system that provides a 240V output, tw0 110vac 180 degree? 1736723859923-2a
Ford F-150 Lightning Ford Lightning with an onboard power system that provides a 240V output, tw0 110vac 180 degree? 1736723983473-0t
Solar controller, input maximums 500DC. output 220vac ( European standard. ) 60HZ. couldn't separator two 110vac.
Peng
Peng
2024 Ford Lightning
I have 17kw solar panels. Currently only have batteries (48x150AH). Not enough. I only have 4kw solar panels installed. Need to install 12kw more (the rest of the solar panels are now staying in my garage).
There is no electricity in the garage. There is room for solar panels on the garage. The garage to the house is about 160 feet. I put several underground cables. One is a 4/6 AWG, one is 4/10 AWG, one is 3/12 AWG cable from the house to the garage.
Ford F-150 Lightning Ford Lightning with an onboard power system that provides a 240V output, tw0 110vac 180 degree? 1736724965928-1
Ford F-150 Lightning Ford Lightning with an onboard power system that provides a 240V output, tw0 110vac 180 degree? 1736725049569-2w
Ford F-150 Lightning Ford Lightning with an onboard power system that provides a 240V output, tw0 110vac 180 degree? 1736725094273-ux
Ford F-150 Lightning Ford Lightning with an onboard power system that provides a 240V output, tw0 110vac 180 degree? 1736725182943-ae
Ford F-150 Lightning Ford Lightning with an onboard power system that provides a 240V output, tw0 110vac 180 degree? 1736725257332-9m
Peng
Peng
2024 Ford Lightning
want, solar first, then ??? f-150 lightning , hydro one? then gas generator? how many ATS. cable couldn't put again. because too far, underground cable expensive.
I just build shed. 40 feet to house. I have two solar controller. one is 10KW. one is 6.2KW. How to connect them together. (could i use one solar power for another controller 's grid power?)
Ford F-150 Lightning Ford Lightning with an onboard power system that provides a 240V output, tw0 110vac 180 degree? 1736728806742-98
Runaway Tractor
Yes
I'm sorry but all of those posts and pictures are not really helping. And frankly makes it worse. Sloppy wiring, contradictory information in various paragraphs. You're talking about non standard voltages too. Canada and the USA (and the F150) use 240/120v at 60hz but you're talking about 220v European power presumably 50hz.
Based on all of this, I recommend against trying to use an $80,000 F150 to do anything. Instead I recommend organizing your equipment and thoughts into a coherent plan with schematics and actual data.
Peng
Peng
2024 Ford Lightning
80000 Lightning is not a battery. It is a car, but we are talking about onboard power here. I just thought I have a 16kw solar panel. Enough to charge my car. Maybe use it like a battery on a night without sunlight
Truck, it's a truck.........:curse:
v2h8484
Tesla Model 3
Looks like you bought a bunch of things without adequate planning. Since you already started setting up an off-grid solar system with a 240V (60Hz config) only inverter which is not appropriate for the US house wiring but maybe OK for a 240V well pump. If you want to connect it to house wiring you will need a split-phase inverter or add an autotransformer. In any case, you should get the solar working first and this is not the right forum to help with that. Check out the DIY solar forums.
