Rivian NACS-CCS adapter, work on Lightnings?
pookguy88
cars
Anyone know if I get the Rivian adapter (looks to be the Tesla OEM one) will it work on our Lightnings? Is the hardware exactly the same?
pookguy88
cars
thank you, now gotta figure out if I should get that one or the A2Z...
pookguy88
cars
Charge_Rob
2024 F-150 Lightning Lariat
Charging Nerd
I'm just going to buy one aftermarket, who knows how long Ford will take ship their adapters
It's worth the wait for the Ford adapter. It's improved vs. the aftermarket designs, and easier to use than the Rivian adapter.
Basis0439
2023 F150 Lightning
Woohoo! A press release to tell us we might get a super great update at some point in the future!
At this point I'm convinced Ford's customer service strategy is "over promise and under deliver!"
Ford adapter doesn't allow level 2 Tesla charging though, which is pretty annoying. does the rivian's?
Charge_Rob
Charging Nerd
Due to the nature of NACS where the same pins can carry AC or DC compared to J1772 and CCS, where separate pins carry AC and DC, any adapter that does both would have to connect the NACS power pins to both the AC and DC pins on the vehicle, which would be quite dangerous. Separate adapters are required for that reason in both directions - Tesla owners need to carry a J1772 adapter for AC and a CCS adapter for DC, we need to carry a NACS AC adapter for AC and a NACS DC adapter for DC.
perpetuality
Nick
2024 Lightning Lariat, 2013 Mazda Miata
My adapter from Lectron is extremely well built and has functioned flawlessly.
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
hmm ok, what makes this one improved?
Ford has higher standards and makes sure the adapter is designed and built to be functional and safe (granted, they did recall some). That doesn't mean aftermarket ones aren't just as good, it's just more likely the Ford one will function as intended without issues.
Ford has tapped Lectron to build some Ford branded adapters. But the Ford branded ones aren't the same as the Lectron branded ones.
It's like aftermarket toner cartridges for your printer. Some as just as good as OEM, some are crap. Get OEM if you want to be certain they will work.
F150ROD
U.S. Navy Retired
Do you know what’s the difference between the Lectron one and the Ford made by Lectron other than the logo?
I wonder what Tesla did wrong with their adapter.
Adventureboy
Pick one
  • Simply too slow on the supply chain
  • Forced into one vendor until certifications came out
  • Priced higher since it is Tesla
  • Difficult to work with Tesla as a competing vendor
There is not a single Tesla SuperCharger adapter on the market that also allows Level 2 Tesla Destination charging. Not one.
Buy this - https://a2zevshop.com/collections/charging-adapters/products/a2z-stellar-plug?ref=Typhoon
Fun facts:
Tesla made Ford's adapters initially. Ford had to recall (cough, cough) their June shipments and replace them. Ford's lawyers got it to be a Customer Satisfaction Program instead of an NHTSA recall (cough, cough).
Lectron had to recall 1,600 of their Vortex adapters and change their design too.
A2Z had to recall their original Typhoon adapter, but the Typhoon Pro is great.
Because Tesla couldn't come close to producing enough adapters, Ford had Lectron make some too. Those adapters started shipping in the past few weeks, and are shipping in volume as compared to Tesla.
You can Google for the difference, it's in the latching.
potato
BC, Canada
2023 F150 Lightning XLT ER
When mixing and matching adapters for the Lightning, you just have to make sure it's rated for 500 amps. I think the Kia one is only 350 amps for example, so you might burn something up if you use it at a high power charger.
