BlueCruise Lane Change not smooth
F150guy
Garrett
2024 Lightning ER Lariat
2024 Lariat ER with only 5k miles. I have Blue Cruise and noticed that when I use the Auto Lane Change feature on the highway going 65mph the process is not smooth. While the lane change is accomplished the steering feels very incremental. It feels like it makes several (4 or 5 I'd say) little turn steps to accomplish the task. Are others feeling that? I expected it to perhaps make only 1. Even if it was two steps I could see that and might make some sense, but 4 or 5 seems odd. Either the software does the 4 or 5 steps intentionally OR maybe the linkage from the motor that turns the steering mechanicals needs lube?
Scorpio3d
SS/IBA car wash owner
May depend on which Blue Cruise version you are on? Mine is very smooth, but I also have all the latest updates. However, I have a 23 lariat so I cannot speak to the 24!
F150guy
Garrett
As far as I know it's the latest. I have no pending updates.
I've noticed the notchiness on corners that are a little sharp for the speed I'm going. Lane changes seem smooth enough but I can't say I've paid close attention.
For context, prior to BC1.4 it barely stayed in it's own lane and actual lane changes didn't exist.
Natedogg1087
Nathan
2024 F150 Lightning ER Lariat, 2019 Ford Edge ST, 2016 Ford Mustang GT
I find my 24's Lane changing to be very smooth though I am traveling slight faster at around 70 to 75MPH.
F150guy
Garrett
The first couple of times I tried the lane changing it was for very short stints only and I don't think I detected the notches. Most recently I had some longer drives and it was certainly there. Maybe it's been doing it all along and I was too new to it in those first short tests.
The 2024's came with BC 1.2. So far no report of any OTA update to BC 1.4 for that year. So you have the latest for 2024 trucks.
Some 2022 and 2023 have received BC 1.4 via OTA. Likely an early test group.
Otherwise folks have enabled 1.4 by doing manual updates via FDRS and FORScan. Or they had their dealer do the Front Sensor CSP last year which gave them BC 1.2/1.3 with a FORScan mod.
F150guy
Garrett
Thank you. I didn't realize a new(ish) truck would start off with software that old.
Natedogg1087
Nathan
It is possible. Though this is my second Lightning so I wouldn't say I'm new to it. I had a 2022 SR Lariat for 2 years. I would say that my experience has been close to the same and at times I find the 24 better.
F150guy
Garrett
It was the latest at the time. 2022 and 2023 came with BC 1.0.
2024 Job 2 Mach-E's got 1.3.
https://www.ford.com/support/how-to...assist-features/ford-bluecruise-availability/
Well, what do you know. Thank you. I see I might have a weaker version. I received 10.1.1 for Sync and I figured I was good to go. Not so. I wonder when an OTA BlueCruise update for my 24 Lariat ER will arrive? Next month I am supposed to renew it if I want to go beyond the trial. Will see about that. And I am not yet educated enough to get Forscan and such. I am still learning that. I have plenty of reading to go.
Richie740
Rob
Walt, I have a 23 Lariat and I don't have the lane change or am I missing something. I know i had the OTA Blue Cruise update that was released towards the end of the year too.
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
My dealer gave me a loaner 2024 F-150 XLT (ICE) for the last week, and the auto lane change is very smooth.
Very nice feature.
Scorpio3d
I’m not sure if the lane change has to be activated with forscan or not? I don’t think it shows up anywhere on the truck as far as settings go But if you’re on Bluecruise and turn on your signal, the truck will move over one lane if you do have it.
astrand1
Alex
Studio truck driver
If you wanna post your vin I can run thru fdrs to see if you have updates available. To your question my 23 is very smooth with auto lane change.
