Turning off Plug & Charge...
On Ford products press the unlock button next to the ccs port
I'm not sure that disabling Plug-N-Charge would solve this issue, as the truck is certainly looking at a charging session activation at the moment you plug ANY connector into the charge port... "PLUG N CHARGE" as actually an additional 'feature', and is purely to resolve having to do anything other than plugging in at a DC Fast Charge location, at least one that has this activation protocol with Ford. EA stations would be the other locations.
Now, as to why the Tesla APP activation did not work, then the truck defaulted to it's OWN billing method, is probably on Tesla's side, not Fords. With Tesla Superchargers, other than hearing the spool-up of power, you really only have one or two other ways to 'know' it is charging: Your vehicle on-screen readout, or your APP, whether Tesla, or Ford.
Additionally, on some vehicles, like our KIA EV9, you actually find that you don't know HOW to STOP the charge: there is no button on the Supercharger unit. There is no 'Stop Charge' within the vehicle, or it's APP, and the only method seems to be some obscure lower button within the Charge Port, with some type of icon, that apparently does the trick. It took some time to find this. Maybe you can also disable charging by pressing the top button on the handle of the NACS cable... who knows.
The point of Plug and Charge IS using the trucks billing method, that is what it is. Without plug and charge there would not be any billing method other than the Tesla app. There is no way for Tesla to bill through Ford other than Plug and Charge.
Point being, if he could disable Plug and Charge there would be no way for Tesla TO bill him. But they did, so this has to be a Plug and Charge failure.
I got you all the way to the last part of the last sentence. It isn't a Plug & Charge failure, it's a failure to turn off Plug & Charge when the app says it is off. I suspect it's really ON. That's why I asked Ford to turn it off.
I don’t think that’s correct. I recently initiated a Tesla session in FordPass - no P&C.
Of course. You can use any network in the Blue Oval Charge Network via FordPass activation, or Public Charge activation. Only EA and Tesla are Plug & Charge though, so you activate anywhere besides those 2 using FordPass or Public Charging, and the activation fails, nothing will happen.
Maxx
So what is the workaround until there is a fix? Can Force stopping Fordpass or turning off connectivity in the truck before charging throw a monkey wrench in Plug and charge process or they have nothing to do with it. Any other ideas?
Same, from my android version 5.10.0 of Ford Pass
Ford Software updates are like a box of chocolate but not quite as sweet.
Force Stop and clearing data cache does nothing, I did not clear credentials as I don't want to eff around with reconfiguring PAAK.
There appears to be issues with FP 5.10.0
They appear to have activated our P&C to active in the database, but that condition doesn't show on my and several members Fordpass' where it was previously switched off, it's stuck off.
IMHO, a massive number of BUG reports to APP STORE and PLAY STORE, as well as the developers email address might prompt an expedited 5.10.1
I’m pretty sure we used to be able to toggle P&C by logging in to Ford.com. It looks like that’s now solely relegated to (unreliable) FordPass.
And on the dash too, right?
I thought there was a PnC setting in the display...although it seems mute since you can't seem to do anything regardless of where the toggle switch is.
Triaspis
Joe
Bordentown NJ
2023 Ford F-150 Lightning XLT
Locksmith
Perhaps I'm confused and not understanding the problem correctly.... but ....
Your trying to use the tesla app pricing and not the Ford P&C pricing tier?
If so, here's what I do which seems to work fine for me.
Right before I plug in, I launch the Tesla app, select charging location, then charging booth/stall ...... Then I hit the "start charging" button ..... And THEN I plug the charging cable/adapter into the truck.
This procedure has always worked for me and seems to bypass Ford P&C as the Tesla app is commanding the charger before I even connect my truck.
I even have Ford P&C activated in my Ford Pass app just in case I wish to use that to activate a charging session while using other DC fast chargers besides Tesla.
Exactly correct.
EXCEPT, if the Tesla session fails to activate, it kicks in P&C which I can't deactivate and says it's off... It's a FordPass Android issue.
Bwanapete
Peter
Cazenovia, NY
2022 Lightning, 2017 Tesla MS90d, 1941 Lincoln V12
I wrote Tesla plus cancelled my Tesla membership discount account. We’ll see what they have to say. Without the discount, the Tesla kW price is the same Ipaid at a nearby Walmart charging station. Not as cheap as gas right now.
I suspect your issue is you never activate the sessions with the Tesla app, you simply plugged in and therefore Plug & Charge took over.
