Departure Times Just Will Not Work
mxracer
Dan
2024 F-150 Lightning Flash
As the title says I cannot get departure times to work on my 24 Flash.
Here's what I have done so far:
Truck is always plugged in at home and is connected to my wifi where it sits
I have created, deleted and re-created the "home"charging location in the truck
I have cleared cache, then uninstalled and re-installed Fordpass
I have created departure times in Fordpass, when they didn't work then deleted them from Fordpass and re-created them directly in the truck, which did show up in Fordpass
When a departure time comes around the truck just does nothing.
I can "remote start" the truck thru the app without issue.
Any thoughts/ideas would be appreciated cause I am at the point of just deleting them and starting it when I need to go somewhere, but I'd really like to take advantage of battery preconditioning.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Twice recently our truck has been confused about where it is parked, and decided it was in a "default" location and wanted to charge to 100%, ignoring programs that was and still exist.
I suggest you delete your location information, unplug, drive around the block and see if the truck recognizes what you programed. If not, perhaps reinstall the data ....
It may not help, but at least it removes this possibility.
21st Century Truck
Martin
I found, on the Lightning and also on the Mach E, that setting these times in the vehicle's SYNC seems to stick better than thru the FordPass.
Also, I noticed that it's best to have the truck see the "home" charging position as the "default". This might, perhaps, help in Your situation...
Final note: on the CHARGE screen in the truck, do You have the bottom (CHARGING LOCATION) toggle turned on?, It's easy to miss that one... it's right below the DEPARTURE TIME toggle.
mxracer
Dan
Thanks, it does seem to know where it is. I set the max SOC at 90% here at the house and that works as it's supposed to. Location in Fordpass also shows the house. I will delete the location next time I go somewhere and reset it when I get back.
Thanks, my last round with the truck was to set everything up in the truck vs the app.
When I get in the truck it does show "default" until it syncs with the server then changes to "home" which is what I edited it to.
The toggle is on, as mentioned above the max SOC for the location works as well.
Was the truck ice cold when you went out to drive it?
Were the tail & marker lights on?
Do you have time constraints on your at home charging scheme?
If you do, what are the start & stop times?
Is the departure event time past the charging limit time?
mxracer
Dan
Yes, no. My last departure time was 5:45PM yesterday afternoon. At 5:40PM I went out to the truck, no lights at all and the cabin was ice cold along with the seats and steering wheel. I then just "remote started" the truck from the app to at least get some heat in the cab. This is exactly what has happened for every departure time I've ever set.
I don't have any charging constraints setup and never did actually. I'm on a coop and my power is same price no matter what so chargin "wide open" for the truck.
Good that you do not have time constraints.
I wonder if your departure time had all days selected and also wondering how you handle the switch for behaviour while off plug.
I would expect there to be no difference in operation since you're plugged in, but if it's OFF, try turning it ON and retest.
I suggest this as a way to determine if there is another bug in FordPass, note this switch is ONLY visible in the APP, you can not see it in the Sync screen.
Ford F-150 Lightning Departure Times Just Will Not Work 1737564727001-2s
Ford F-150 Lightning Departure Times Just Will Not Work 1737564747689-q9
mxracer
Dan
This is my full schedule that shows in the app and in the truck. I don't have a daily commute so the schedule are just the times I know I'll be leaving the house. I did have that toggle on when I first got the truck but have had it turned off for a while now. Will try toggling it on.
Ford F-150 Lightning Departure Times Just Will Not Work Screenshot_20250122_115518_FordPass
