Purchased the A2Z j1772 ext cord
Lightning&Bolt
Matt
Delco
23 Lightning XLT ER, 23 Chevy Bolt EUV Premier
I purchased the A2Z j1772 extension cord a few weeks and it was delivered this week:
https://a2zevshop.com/products/j1772-extension-cord-48a-16ft-5m
I have a single wide driveway that can fit two cars. Prior to getting this extension cord, I needed to swap car positions to be able to use my Wallbox.
I have since charged my Bolt EUV and Lightning using the ext cord, without issue. It says its rated up to 80a (19.2 kw).
Will be interested in seeing how it performs in the summer heat of the Northeast.
Madtroniks
Diamond Sponsor
Ford
Let us know how it goes. Thanks for sharing your experience.
I’m looking forward to the DC extension cable and will purchase one to have with me at all times.
it will come in handy during holidays with Tesla stations where only 8 stalls are available.
Discount promo code “FORD” is still working and free shipping is also available.
I hope we can used it on the cord.
A2Z EV - DCFC - NACS Extension Cable
potato
BC, Canada
2023 F150 Lightning XLT ER
The product you linked is only rated at 48 amps. If you ever try and use it on an 80 amp charger it might get spicy :)
MountainAlive
Massachusetts, USA
2023 F-150 Lighting ER 512A Max Tow
Was the DC extension cord available? The site still says out of stock and I thought that hadn’t launched yet.
Lightning&Bolt
Matt
Delco
Ford F-150 Lightning Purchased the A2Z j1772 ext cord IMG_1025
Mmiketa
Virginia, USA
'23 Lightning Lariat ER
You can’t get 80A on a J1772, ford used CCS for that so you’re good.
Madtroniks
Diamond Sponsor
Ford
Still under testing. Here is the latest update from CEO of A2Z and the engineer.
Nikos
Nicholas
Taylors SC
F 150 Lightning
Aircraft Mechanic
It will do just fine. Use it for L2 level charging. I have one when I go camping with my travel trailer. I have to reach my truck when I plug at the 50 amp outlets. It works all the time even when it is 100F outside.
Lightning&Bolt
Matt
Delco
UPDATE: The cord works fine. I leave it permanently connected to my Wallbox charger. That being said, I am disappointed in A2Z. This extension cord does not feel heavy duty and is noticeably lighter that my wallbox charger cable and connector. I expected an A2Z designed cable and got a cheap mass produced cable that A2Z put a brand sticker on.
Nikos
Nicholas
Taylors SC
F 150 Lightning
Aircraft Mechanic
It will do just fine for L2 charging.
I have one that is 50 feet long to use when I am camping at 50 amp outlets.
It's rated for 80amp, and you're charging at 48amps or 40amps. So what's your concern? "Feel"?
