Anyone install rear blocks?
Clark
Regina, Canada
2017 Lariat, 2021 XLT
Mechanic
Anyone install rear blocks? What did you use? There doesn't seem to be many options out there yet.
Rough Country has them but also come with the front spacers, but I just installed spacers today.
The 2021 FX4 rear block setup is different than the 17 Lariat. The U bolt is more round on the 21 as opposed to square on the 17. So they aren't interchangeable.
Gen14
Midwest
2021 F150 XLT 302A
I just got my order of 2.5" rear replacement blocks from Stage 3 motorsports. Stock blocks are 1 1/4-1"1/2 tall on my CC 4x4 NON FX4 with Max tow. I have a 2.5" level and want a little rake for towing. It should lift the rear 1" supposedly. The kit I bought was Eibach 2.5" rear blocks and it said it fit the 21's. It came with new U-bolts but I haven't installed. I'll let you know it will probolly be next week.
Clark
Regina, Canada
Mechanic
Oh awesome, would you send me a pic of the parts?
In the 17 we had 3" F&R and it was good, slight rake. After installing just the front on the 21, the front definitely is too high lol. So looking for 2.5 or 3" rear block.
Gen14
Midwest
2021 F150 XLT 302A
Here ya go
Ford F-150 Lightning Anyone install rear blocks? 93C9F0DC-F15B-479E-B065-1BA7644D8B4E
Ford F-150 Lightning Anyone install rear blocks? 4CB3F464-8767-4716-82FA-03EAA7308444
Clark
Regina, Canada
Mechanic
I don't know if that is gonna work for you, those u bolts are too square I think, here is a pic
Ford F-150 Lightning Anyone install rear blocks? 20210327_153725
JCU Delt Ox
Ohio
2021 F150 Raptor
I did the ones that come in the Rough Country kit today. Didn’t run into any issues other than have to remove the arm for the headlights prior to removing the existing u-bolts. I don’t prefer to stack blocks, but it was cheap.
Clark
Regina, Canada
Mechanic
What did the U bolts look like? I had Rough Country in the 17 and they definitely did not work in the 21
JCU Delt Ox
Ohio
2021 F150 Raptor
They were more round like they should be for the 21’s.
KartRacer25
Richard
San Diego
2021 F-150 SuperCab Sport 4x4 5.0 3.73 Space White
Senior Software Engineer
Anyone try and remove the 1 inch stock block to drop the rear one inch yet?
Does this only come on 4x4 not 4x2 ??
JCU Delt Ox
Ohio
2021 F150 Raptor
Great, so you ordered this kit, and stacked the rear blocks for like 3 1/4, in the rear?
You got it, 57100 is correct. I ordered mine from Truckspring.com. I wanted to maintain some rake. My Readylift kit up front is going in next Friday.
Clark
Regina, Canada
Mechanic
Ok, yeah I want rake as well. Had 3&3 in the 17.
JCU Delt Ox
Ohio
2021 F150 Raptor
A couple quick pictures of the blocks installed. I'll grab a side shot once the level is on. I'll be running stock wheels and tires with the level for a couple weeks before the Fuel's arrive.
Ford F-150 Lightning Anyone install rear blocks? Lift Block 1
Ford F-150 Lightning Anyone install rear blocks? Lift Block 2
JAGSarge
Joe
TEXAS
2014 Ram SCREW 4x4
Fed. Gov. Paralegal
If you haven't already, do some homework on stacking rear blocks guys and then decide if stacking is the route you want to pursue.
If you have & you're cool with it, more power to ya' ?
JCU Delt Ox
Ohio
2021 F150 Raptor
Or how about enlightening the group with some education? I see all sorts of stories about guys that stack blocks on lift kits and then go hard off road and are disappointed. Having 6" of homemade blocks stacked is considerably different. Show me where under normal conditions that a 1" block, with dual locating pins, is unsafe. When someone else releases a compatible single block that isn't outrageously priced, I'll probably go that direction, but I don't anticipate having any issues in the interim.
