RickKeen
Agree with the suggestion to run 125 amp sub panel. That will give you the ability to expand to two chargers in the garage someday.
Section 384 covers strut-type channel raceways and there is no part 15.A quick Google search said 384-15
And I was in error, it's 42 branch circuits (not 40).
I know that on my main breaker panel (42 positions), there is a part of the bussbar that needs to have a notch in order for tandem breakers to be inserted. That notch is present in smaller panels, but not in the large panels.
ETA….I think that was in the code at one time, but was removed. Perhaps in the 2017 version.
I didn’t buy a new truck. I bought a used truck from a dealership so I hunted until I found a brand new Ford charge station that a fellow was willing to sell me for $500. Because they had sent him too. He had had a truck on order they sent him a charger and he canceled the order and bought a truck sitting on a lot somewhere at a Ford dealership. The Ford charger station requires 80 amp wire 100 amp breaker and my panel is on the opposite end of the house. They asked to use copper wire would’ve been ridiculously expensive and I actually did buy a heavier wire that I needed meaning I didn’t need the extra wire. I bought a four wire instead of a three wire with ground, but in order to save the ridiculous price of the copper wire we ran to a disconnect next to the charger in aluminum and then ran from the disconnect into the charger itself in copper as recommended and required by the manufacturer. I hope this information helps a little bit.I will be using a licensed electrician but have read / seen on internet many licensed electricians unfamiliar with ev chargers, so hoping for some info here.
I purchased the ChargePoint home flex. Ideally would like to charge as fast as possible hardwired with the charger in my garage, but there is a great distance between my panel and garage, probably about 75 feet….also I might not have the room in my panel for higher amps….
so I’m open to suggestions. Luckily for me I have numerous low cost / free chargers available so rarely charge at home anyway (currently on level 1 outlet), but with tax write off and discount purchase through utility I figured I’d get the home charger, plus maybe I will be able to precondition the vehicle now.
Pics attached.
thanks in advance
I didn’t realize it happened that long ago. Thanks for the reference.This was found in the 2005 nfpa 70, removed for the 2008 version.
408.35 Number of Overcurrent Devices on One Panelboard
Not more than 42 overcurrent devices (other than those provided for in the mains) of a
lighting and appliance branch-circuit panelboard shall be installed in any one cabinet or
cutout box.
A lighting and appliance branch-circuit panelboard shall be provided with physical means
to prevent the installation of more overcurrent devices than that number for which the
panelboard was designed, rated, and approved.
For the purposes of this article, a 2-pole circuit breaker shall be considered two
overcurrent devices; a 3-pole circuit breaker shall be considered three overcurrent
devices.
It does not.The Ford charger station requires 80 amp wire 100 amp breaker and my panel is on the opposite end of the house. They asked to use copper wire would’ve been ridiculously expensive and I actually did buy a heavier wire that I needed meaning I didn’t need the extra wire. I bought a four wire instead of a three wire with ground, but in order to save the ridiculous price of the copper wire we ran to a disconnect next to the charger in aluminum and then ran from the disconnect into the charger itself in copper as recommended and required by the manufacturer. I hope this information helps a little bit.
I’d bet money that your entire house is fed by aluminum wire.Personally, I refuse to use aluminium wire but your budget may vary.
The main feed was installed underground in 1971, could be al, I've never worried about that part.I’d bet money that your entire house is fed by aluminum wire.
I needed truck to fully charge overnight. I was unable to do that with the 32amp reg charger. And our AEP rates are ridiculous so I only wanted truck to charge after 10:00pm and finish by 8:00 am.Thanks everyone for your help. I think I may go with an outlet instead of hard wiring b/c I probably don't need the extra power...what type of outlet did you guys use and what wire? I was thinking of buying the thicker wire just in case we change our mind in the future...
I went with the garage sub panel when we remodeled the garage and installed the charger. I now have powered outlets and lights in the garage, outlets out back near my garden, and a FCSP which I down rated to 60 amp and set up to only charge when I am sleeping. Works like a charm.Sparky here. Have the electrician run 1/0 aluminum ser to the garage. Put in on a 125 amp breaker (this is the largest breaker you can get amperage wise that is a normal size that will fit in that panel) then install a 125 amp mlo panel on the garage. Yank out all the garage circuits from the main pain and place them in the garage panel. Now you will have a few extra spaces in the main panel and have plenty of headroom for growth in the garage panel.
