Whoskyle
What part numbers did you use? I’m assuming you added after the fact?Make backups of all the modules below before you make changes and ignore whatever you have where's x's are and just change the non-x values. Ignore any warning FORScan gives you about "incorrect checksum" and continue with the write.
APIM 7D0-01-02 xxxx xxxD xxxx
APIM 7D0-09-03 xxxx xxx4 xxxx
APIM 7D0-01-03 xxxx 25x5 xxxx
BdyCM 726-69-02 xxxx 01xx 01xx
IPC 720-03-02 xxx9 xxxx
IPC 720-07-01 xxxx xCxx xxxx
IPMA 706-18-01 xxxx xxxC xxxx
TRM 791-01-01 xxxx xxx1 xxxx
PSCM 730-02-02 xxxx xxxx 03xx
