Wait.... how did you run your power? This is exactly what I want to do.Well I took it one step further and installed the MagSafe charger in the little cubby. Turned out good. Now I just throw my phone up there and it charges
TL;DR: The charger in this tray is terrible.My daughter ordered this.
https://www.amazon.com/Wireless-Organizer-2015-2020-Container-Accessories/dp/B08C9ZQFR2
Works through her case.
I like the sides on that one from Amazon. It looks like it would really hold the phone in place. But, do you know if it would fit easily in that forward compartment in the center console?The built in charger is garbage. It will not stay connected to the wireless charging pad whether case on or off. I have an iphone12Pro and it's a pain in the ass. I have switched to a magsafe charger but before that, if you want something close, this works great. Never had an issue.
Amazon.com: Wireless Charging Pad Car 15W 10W 7.5W Q Fast Car Wireless Charger Pad Stand Station Mat, Phone Holder Car Wireless Charger Mount for iPhone 12/12 Pro/11/11 Pro Max/XS Max/XR/X, Galaxy S10/S9/S8: Electronics
If you haven't used magsafe yet just know it's not a light magnet hold. If you are planning on leaving the charger in the car you will not be able to lift the phone off it without picking them up and pulling with some effort. Not a lot of effort but the magnet won't allow you to lift the phone without also lifting the charger.Anker Magnetic Wireless Portable Charger, PowerCore Magnetic 5K Wireless 5,000mAh Power Bank with USB-C Cable, Only for iphone 12/12 Pro / 12 Pro Max / 12 Mini https://smile.amazon.com/dp/B08TW7BRTJ/ref=cm_sw_r_cp_api_glt_fabc_2ZCBWEWSAXNM9PGYMT0M
Was thinking about something like this? Wireless charging and having a battery backup in case you need to take it on the go.
Its a good one for sure. No adjusting. But I don't have it any more. Should be measurements on the link. It fit in my 2019 Ranger tray no prob.I like the sides on that one from Amazon. It looks like it would really hold the phone in place. But, do you know if it would fit easily in that forward compartment in the center console?
Thanks.
I remedied that...If you haven't used magsafe yet just know it's not a light magnet hold. If you are planning on leaving the charger in the car you will not be able to lift the phone off it without picking them up and pulling with some effort. Not a lot of effort but the magnet won't allow you to lift the phone without also lifting the charger.
I hope that makes sense.
I added a dedicated USB A and C socket to the back of the Center console storage under the arm rest. Ran the Magsafe cable back to that. This way I get the full 15 watts Magsafe Charging. This is the charging socket I used. Connected it using fuse taps in the panel at the passenger side. Amazon.com: 【2021 Lastest】 Quick Charge 4.0 PD Type C and Quick Charge 3.0 USB Charger Socket, AlfredDireck 12V USB Outlet Car Power Outlet Waterproof Socket with Dual Ports for Marine Boat Motorcycle Truck Golf : AutomotiveWait.... how did you run your power? This is exactly what I want to do.
Great work! Thanks for the info. Now I've got my next little project queued up.I added a dedicated USB A and C socket to the back of the Center console storage under the arm rest. Ran the Magsafe cable back to that. This way I get the full 15 watts Magsafe Charging. This is the charging socket I used. Connected it using fuse taps in the panel at the passenger side. Amazon.com: 【2021 Lastest】 Quick Charge 4.0 PD Type C and Quick Charge 3.0 USB Charger Socket, AlfredDireck 12V USB Outlet Car Power Outlet Waterproof Socket with Dual Ports for Marine Boat Motorcycle Truck Golf : Automotive
It does and thank you for the heads up. Was also worried about keeping a battery plugged in that long in the truck.If you haven't used magsafe yet just know it's not a light magnet hold. If you are planning on leaving the charger in the car you will not be able to lift the phone off it without picking them up and pulling with some effort. Not a lot of effort but the magnet won't allow you to lift the phone without also lifting the charger.
Ok - issue with this.I've been meaning to do this since I picked up my F-150. I think its nonsense how some Lariats can top $75,000, and XLTs and XL can easily crest $50,000 and somehow we are blocked out of having the wireless charging option that is afforded to the King Ranch, Platinum, and Limited trims.
Well, friends, I've found a pretty good, if not better, alternative for us lowly Lariat lovers who want a wireless phone charging option for their trucks.
Here is what I did to combat Ford's cost cutting:
I have used Anker phone related products in the past, and have had pretty good luck with them. Way back in October when I was in the process of placing my order, I was considering buying one of their wireless charging pads for the truck. since that time, it looks like Anker has released a smaller, more powerful model.
I picked up the Anker PowerWave Base Pad. This item seems extremely well thought out especially for purposes of being used in the F-150s. The top and bottom surfaces have a rubber texture to better grip onto the phone as well as the surface it is placed on.
The device also has vents along the sides on the bottom to help with cooling, and mitigate overheating.
Here is a quick look at what comes in the box:
The Anker PowerWave is also able to charge through normal phone cases up to five millimeters thick.
I placed the PowerWave in the storage cubby directly underneath the Productivity Screen and climate controls. I also purchased a six inch USB to Micro USB cable to plug into the truck's USB port to run power to the PowerWave. I elected to get a ninety degree angle cable so it sits more flush with the device and saves as much of the cubby space as possible.
Here are a few pictures of it installed in the truck:
SUCCESS!! We have wireless charging in my F-150 Lariat!!!
Quick, easy, job done!!
Ahh, good to know. I have an iPhone 11 Pro with a rubber-esque type case. It works fine for now.Ok - issue with this.
I just got a new iPhone 13 Pro with an Apple leather case. The new case has a bigger lip around the camera. It lifts the phone just enough that it the rubber bits on this charger don't touch the case enough to hold it.
When I turn or accelerate my phone just slides off.
