Lpetters84
Landon
Kentucky
2021 F-150 Platinum FX4 5.0
I’m very new to the Forscan world. If I download the free 2 month license will I have to purchase at the end of 2 months or do you just generate another key?
Livnitup
Livnitup
2021 F150 Platinum
You can keep generating a new license key every 2 months without buying a license if you want.
Livnitup
Livnitup
2021 F150 Platinum
Just realized I had omitted the 740/741-06-03 values below on the Global Open/Close on the spreadsheet so it's been corrected and these are the values:
DDM 740-06-02 xxxx xxxx 01--
PDM 741-06-02 xxxx xxxx 01--
DDM 740-06-03 01xx xxxx xx--
PDM 741-06-03 01xx xxxx xx--
BCM 726-11-02 xx01 xx01 xx--
BCM 726-22-01 xxxx xxxx 01--
BCM 726-22-02 xxxx xxxx 01--
Wilsons66605
Scott
Topeka KS
2021 Power Boost Platinum, 2019 Raptor
Im looking to turn off the fake noise that comes out of the hybrid as well as the backup beep. Is tjat possible?
Livnitup
Livnitup
2021 F150 Platinum
I haven't looked into the fake noise yet but I did look into disabling the hybrid backup beep and after researching it appears the only way to disable is physically disconnecting the speaker because the module that controls it doesn't have any asbuilt values that can be changed.
jgil
Brooksville
2021 F150
Thanks to everyone involved , I appreciate your hard work!
bpost
Bob
2021 F150 Limited
Icewraithusa
Craig
Denver, CO
2021 F-150 XL 3.5 EcoBoost
Can confirm:
Disable key-in ignition chimeIPC720-02-01xx*xxxxxxx--unconfirmed - subtract 8 from current value (if E change to 6)
Also for:
Turn Signal Flashes (# of)SCCM724-01-01xxxxx*xxxx0=1 flash, 4=2 flashes, 6=3 flashes, 8=4 flashes, A=5 flashes, C=6 flashes, E=7 flashes ** see SCCM spreadsheet for more options **
I found that it’s now xxxx-**xx-xx and when I set it to 1A I got 6 flashes, 1C got me 7. Starts with 0C (3 flashes) and 10 gave me 4. Unsure what the big step sizes indicate now?
Icewraithusa
Craig
Denver, CO
Anyone able to confirm the DRL options? I seem to have managed the low beam and amber bulb, and I wanted it to be the fogs and whatever the normal DRL is supposed to be. For some reason trying to load all from my save doesn’t seem to set the original values…
Can’t get Bambi mode to work either.
Livnitup
Livnitup
2021 F150 Platinum
Can confirm:
Also for:
I still need to do some more testing but I believe the values below are valid. Some people have HSW enabled and have the 8 whereas others like me have 0 even though I have a HSW so mine is likely enabled in a separate module.
"Lane Change Blink Number: if your default value is 8C:
80=null, 84=1, 88=2, 8C=3, 90=4, 94=5, 98=6, 9C=7, A0=8, A4=9, A8=10"
"Lane Change Blink Number: if your default value is 0C:
00=null, 04=1, 08=2, 0C=3, 10=4, 14=5, 18=6, 1C=7, 20=8, 24=9, 28=10"
Icewraithusa
Craig
Denver, CO
I have the all the tow options, perhaps that’s making the difference to the starting position?
Sentinel1201
DFW
2021 F150 Powerboost
@Livnitup I am so glad to see you still offer this service for our community. I remember how much I loved having forscan to setup my 2017 Raptor years ago, and now traded that for a 2021 Powerboost and so glad you are still supporting Forscan.
I saw the spreadsheet and already coded lincoln autofold, door & seat belt chimes, global windows, idle shutoff, tranny temp and bambi mode. I am about to do a level kit and get bigger tires and wondering if the tire size in BCM is verified as working? I see the link to the size calculator and wondering if anyone with a 2021 has verified that we are able to write those values to BCM to heal the speedo.
Thanks again,
Livnitup
Livnitup
2021 F150 Platinum
Thanks again,
Yes, there's been a few guys that reported changing tire size and doing the PCM relearn to put their speedo spot on.
Sentinel1201
DFW
@Livnitup is there a way to default the startup mode to Eco? It would be nice to not have to turn the drive mode each time you startup but set it to a particular mode you drive in the most.
Livnitup
Livnitup
2021 F150 Platinum
I haven't found a way to make it default to any particular Drive Mode yet.
