2023 Lightning Lariat - Heater Not Working
Adventureboy
Ontario
I agree, fill it again. I might take a few drive/cool cycles to pull the coolant in and expel the air pockets. If you still have no heat you should call your service department. They should be able to see if the truck is throwing any codes.
There have been cases where the coolant freezes in the pipes to the cabin heater but I don't think you are cold enough for that.
grizwizwg
Walter
Arizona
2023 Ford Lightning Lariat ER, 2023 Mach-E Premium
I'm grateful for the input. Going to let it sit overnight, put enough coolant in tomorrow to get closer to the Max line, and will keep you all posted. I'm gathering heat should clearly come back soon, so won't wait too long on that.
grizwizwg
Walter
Arizona
Update, I added an additional 1 quart of coolant. The level in the reservoir was near the Max line. Drove around for about 30 minutes, hilly areas, heat (actually cold) on blast, no joy on the heater. Came home, coolant level was about exactly midway between Min and Max. Coolant is definitely working through the system, hopefully pushing out air pockets. Seems to be holding steady there. No signs of leaking underneath the truck, on the pavement, or anywhere I can see underneath with a garage creeper & flashlight.
Going to try again tomorrow. On the plus side, temps are above 50 again :)
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Here is a video that shows what your dealer should have done to remove the air from the system. This video shows the air removal from a Mach-E with two reservoir bottles, but the process is the same for our one reservoir bottle Lightning. Go to the 29 minute portion:
Adventureboy
Ontario
I think at this point, it is a dealer call. You've taken the steps to remove the obvious. Let them fix it now.
tearitupsports
Russell
Houston, TX
I ended up having to add about 3.5 quarts total until it finally has a steady level. My heat has now returned to really good levels. That being said mine got progressively better each quart I added, so you may have a secondary issue. When it was bad I could feel my heat cycling on and back off (warm air to cold air and back about every 10-20 seconds).
The good news with mine is that there seem to be no permanent damage issues. I took a 5000 mile road trip being 3 quarts down in the middle of the summer. I started hearing sloshing sounds when at charging stations and should have checked sooner. It wasn't until I researched on my heat cycling issue that this forum pointed me to the answer.
grizwizwg
Walter
Arizona
It's been about a month now. I've added coolant 3-4 different times since January. Thankfully, it hasn't been exceptionally cold, but the heater is still not working. In the beginning, when I had no coolant, the added fluid would go down very quickly after driving. Fast forward a month later, I just added maybe a cup of fluid to get it close to Max level after driving for 2 weeks. Hence, the coolant level seems to be settling...maybe finishing distribution?
But, with no heat, no doubt I need to take it in. I also have a recall now "Upper control arm ball joint nut replacement." I have no idea what that is or how serious it might be, but seems I can get that and the heater done in the same drop off.
Adventureboy
Ontario
This is the joint that holds your wheel hub on your truck, so it is important. Some of them were not torqued properly for some build dates. You definitely want to have that verified, although most are ok.
It's been about a month now. I've added coolant 3-4 different times since January. Thankfully, it hasn't been exceptionally cold, but the heater is still not working. In the beginning, when I had no coolant, the added fluid would go down very quickly after driving. Fast forward a month later, I just added maybe a cup for fluid to get it close to Max level after driving for 2 weeks. Hence, the coolant level seems to be settling...maybe finishing distribution?
It'll be interesting to hear what they find, either PTC or diverter valve are most common failures.
grizwizwg
Walter
Arizona
Alright, gents...truck is in the shop and I should know what the deal is with the heater soon. Recalls on the Lightning (upper control arm ball joint) and Mach E (windshield wiper motor inspection) performed this AM. They said the truck threw some error codes, but didn't expand on what they were. Will let you all know what the outcome is as soon as I get it back.
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
Sounds like there's no low level alarm on this critical battery health system. Thought that was a thing from 20 years ago on ICE & hybrid vehicles. Why not on the Lightning & assume Mach-e's ??
Correct, but your windshield washer fluid is well monitored ?
I feel like there was a corelation between low coolant levels and burned out heaters but that is only based on a few comments here.
grizwizwg
Walter
Arizona
The results are in! A faulty heater is what I am told. I have some screenshots to share since many of you are far better at deciphering the lingo than I. Curious to hear if anything more detailed can be distilled from it.
From a customer perspective, Chapman Ford in Scottsdale took great care of me, had a loaner ready upon request, and remedied all this in a couple days. For those folks in AZ, the Chapman team has been great with EVs. So consistent, reliable, and strong customer service-wise that we make the 3 hour round trip to go there. Highly recommend.
Ford F-150 Lightning 2023 Lightning Lariat - Heater Not Working Heater Replacement 1
Ford F-150 Lightning 2023 Lightning Lariat - Heater Not Working Heater Replacement 2
https://www.tascaparts.com/oem-parts/ford-heater-assembly-auxiliary-rl3z18k463a
Ford F-150 Lightning 2023 Lightning Lariat - Heater Not Working 1742352062537-l
