Anybody else notice the slight "Click" when starting off either in forward or reverse?
MapleMan650
Santa Cruz Mountains
'22 Ford Lightning Lariat ER, 2017 Ford Mustang GT
I.T.
No official word of a recall or TSB from my service center. But the guy I spoke with on the phone did say that Ford told them to replace the axle.
I swear I was hearing the clicking sound from the front and rear but we will see!
nubkub
Half Moon Bay, CA
2022 Lightning Lariat ER
Graphic Designer
Had my lariat since Monday. I also hear the click with windows open when I accelerate from a stop. Only have 450 miles on the truck so far.
PV2EV
Maybe the CV joints are undersized for the torque and weight of the truck?
Paulightning
Paul
1993 Cobra, 1995 Bronco, 2022 Lightning Lariat ER
I've had the click since day 1 as well. Had 73 miles on it off the transport truck. Only time I ever hear it is with the windows down from a stop. I have over 2300 miles on it.
nubkub
Half Moon Bay, CA
Graphic Designer
Just had it at the dealer. They could not figure out what the noise is and how to fix it. They opened a ticket with engineering at Ford. Their demo truck makes the same clicking noise.
MapleMan650
I.T.
Our explorer st does this all the time. Its the splines in the cv shafts moving inside the hub splines.
This is what my dealer said it was too. They said they replaced something today and the click is gone. I’m going to pickup the truck tomorrow and see.
They said whatever they replaced today was a onetime use part. Maybe the spindle nut? I wonder if they just replaced the spindle nuts and torqued everything down. We’ll find out tomorrow! I’ll post my work order and let you all know if the tick is gone.
RavenYZF-R6
Denver
Tacoma
My Pro has done this from day one. They’ll probably fight me on the warranty coverage with a 2” level kit too lol.
nubkub
Half Moon Bay, CA
Graphic Designer
Please for sure let us know. It was sad to have my truck at the dealer all day and find out they did nothing but report it to Ford Engineering.
Getting it reviewed by another shop and reported to Ford engineering may be the best thing you can have happen. I know it doesn't fix yours specifically, but it is documented and by now it seems Ford should start to have enough data. They likely know what it is by now, they just have to determine what a fix is and how it gets rolled out.
MapleMan650
I.T.
Just picked up the truck and the clicking and ticking sound is gone! Here's what the work order says:
Verified customer concern. Click noise is coming from the front CV axle shaft splines. Recommended disassembling the CV axles and re-grease splines. Gained access both Left and Right front half-shafts, cleaned and re-greased CV splines per previous diag. Rechecked for noise, no longer present at this time.
Parts NumberDescriptionQuantity
W720613S439BOLT AND WASHER ASY ...4
W520215S440NUT - HEX. 2
W707772S441NUT ADJUSTING SCREW4
W717969S440NUT4
W706890S439BOLT8
They also adjusted my tire PSI. ;)
nubkub
Half Moon Bay, CA
Graphic Designer
W520215S440NUT - HEX.2
W717969S440NUT4
W706890S439BOLT8
Thank you for sharing. I hope they will do the same for for all of us tickers. It really is an annoying sound.
lightspeed
2023 Lightning Lariat ER
Hmmm CV joints are normally drowning in grease (held in by the boot). Interesting that someone forgot to grease just the shaft spline where it mates with the outer CV inner race? Is that what they say is happening?
