Best charging pattern to use
Tauer
Tony
2023 F-150 Lightning XLT SR
Software Engineer
I work from home and usually don't drive more than 20 miles a day, so my power usage is pretty low. I always charge at home on a 120v plug. I charge up to 70% on the weekends and that's usually enough for the week, ending up around 30% by Friday night. I'm considering changing that to where I just plug in whenever I'm home, with my charge target set to 70%. That way I've always got decent range in case I suddenly need to take a longer drive. Does anyone know if one of those charging patterns will be any better for the batteries? I know that expansion is one of the things that is rough on the batteries. Will keeping the batteries near 70% with very shallow discharge/charge cycles be any harder on them than the 70%-30% cycle I'm using now?
Heliian
Get a 220v evse.
Ford says keep it below 90%
Ford says keep it at 50% for storage longer than 30 days.
Rule of thumb is to keep it above 20%.
SpaceEVDriver
Arizona
Shallower charge/discharges are generally better, but it's not going to make a major difference if you charge 10% a day or 12% or 7%.
Firn
23 Pro ER
More frequently, smaller charges, are better than less frequent, large charges.
Or put more simply, the best is to charge daily.
queuewho
Western PA
22 F150 Lightning Lariat SR
I usually keep it 50-70% during the week, but charge to ~95% if heading to the Laurel Highlands for the weekend. If I had to guess, even after 8 years, if you are doing things 'wrong', there will be very minimal difference in performance in the end.
SpaceEVDriver
Arizona
This last bit. With the cells rated for 2000 or so full cycles at a 1-hour discharge rate (DCFC at 130 kW) before a loss of 20% or 30% capacity, your battery has a long, long life ahead.
flypony53
Rodney
Houston, TX
I'm particularly interested in this snippet:
" Pressing the pedal with your foot hard does not speed up aging. If anything, it slows it down, explained Alexis Geslin, one of three lead authors of the study and a PhD student in materials science and engineering and in computer science in Stanford’s School of Engineering. "
How I read that is "enjoy the car's acceleration everytime you can!"
